Question about Philips Audio Players & Recorders
Philips AZ-6000-05 DAB/CD Player plays ok with batteries but not with mains 230v connected. What is wrong and how can I get it fixed! trevor.creasy@sky.com
SOURCE: Not working
Check if the power signal in the base turns on. If not two things can be appening. The base or it's transformer is damaged, or the output jack of you soundboard is dead. Check the sound form the soundboard with some regular headphones to find the source of the problem.
Make sure that the base and the wireless phones are on the same channel and you batteries are fully charged.
Posted on Jan 08, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Philips Gogear 1GB - File format not supported
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sure you are connected to the internet first).
Posted on Feb 19, 2008
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Posted on Mar 06, 2008
SOURCE: Philips DA1102 DAB+MP3 Portable Player
USE REAL PLAYER TO TRANSFER TRACKS TO YOUR DEVICE
MAKE SURE MP3 FORMAT
SYNCRONISING WORKED FOR ME
Posted on May 18, 2008
  • 1348 Answers
SOURCE: Mains hum on Ferguson R121 DAB radio
wrap aluminum foil around the power cord
Posted on Jul 19, 2009
NOT PLAYING MP3 CD
It doesn't play them!!
It will play copied CDs but it can't read MP3 files from a CD.
Sorry
Feb 25, 2011 | Philips AZ 1027 RadioCassetteCD Boombox
-Hold button keeps displaying
The unit has a hold button that keeps you from accidentally activating the device when it's in a purse or backpack, which preserves battery power and also prevents changing tracks if buttons are accidentally pushed while in play mode. Look on the player for the hold button and turn it to the off position. I hope this helps and good luck!
Feb 17, 2010 | Philips eXp2461 Personal CD Player
Can mp3,ipod connect to philips FW-R7 with cd
All you need to get them to play is a "dock" and a 3.5mm Jack to two RCA phono plugs lead.
The Jack goes into the headphone output and the RCA's go into any spare socket on the back of the unit IE tape/cd.
Infact you just need the lead, plug it into the headphone output of the Ipod or MP3 player. But the dock will keep the battery charged and you get a remote with the dock, so you don't need to get out of your chair, to operate the player.
Feb 08, 2010 | Philips FW-R7 CD Shelf System
MY HUSBAND'S PHILIPS DAB RADIO SEEMS TO HAVE SELF-COMBUSTED! THE CASING HAS MELTED AND IS TOTALLY KAPPUT! PRESUME THAT IT MUST HAVE BEEN THE BATTERY, BUT LOOKS QUITE DANGEROUS
If its running through batteries then its probably due to rechargeable battery else if it runs through power cord connected to mains then its totally due to manufacturing fault.
Thankyou
Jul 31, 2009 | Philips DA1000 FM Radio
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Philips memory corruption Problem
Could be corrupt firmware:
Install and run Philips Device Manager from the product CD.
Press and hold [PLAY/PAUSE] on the player whilst connecting to the PC.
Follow the on-screen prompts.
This will format the player and replace the firmware.
May 02, 2008 | Philips SA5125/37 MP3 Player
Az 1574 Philips radio
Unplug the unit and take out any batteries ( power down the unit completely), Let the unit dry out for a few days or dry with a hair dryer ( low heat ). If the unit still dosn't work I would assume water has damaged the main board ( process board etc. ). If that is infact the sitution, chances are the unit is not worth fixing. Sorry for the bad news. I hope it works out for you.
Ed
NC Electronics
Mills, Wyoming
Jan 06, 2008 | Philips AZ1574 Cassette/CD Boombox
79 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
