Question about Sony DAV-FC7 System
High pitched squeal thru all spkrs when input to unit from vidieo 1and 2
The sound quality when i play a cd or a dvd is excellent.However,when I switch to the FM radio function there is a high pitched squeal along with the radio.In addition to this,and most frustrating,is when i switch to video one or vidieo 2 to watch HBO,cinemax ,or XM radio thru THRU DIRECT TV,I also get the annoying squeal
I have also had all the other dvd/cd ejection/standby problems with this unit when new.Thank god I bought an extended warranty and after being in the shop at least 6 times these problems were corrected
Now it is in a shop again(for over two weeks) and the tech still hasn't found the squeal problem.PLEASE HELP!!!!
  • Anonymous Aug 24, 2008
    I am having the exact same problem... Our DAV-FC7 has had no problems until recently when it started having a high-pitched squeal on FM and TV Tuner whenever I turn the machine off, then on again. Eventually, it fades (in about 30 minutes to an hour) and I can hear again. But once it is turned off, the squeal occurs again when turned on.
    I have checked all connections, cables, and proximity to tv, other devices...to no avail. No idea what's causing it, and warranty just ended as well... of course!
  • hoops1 Jan 24, 2009
    i dont understand what this solution means can i get an answer for dummies
  • 3 Answers
Replace C602 on DVD board, noise on 10v line causing problem.
Posted on Jan 22, 2009
I have the same problem, the solution looks like it is to replace a capacitor on the main board.
Posted on Mar 02, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Poor sound quality from external line
it may be the recorder itself.. these smaller recorders arent known for excellent recording quality..what is it set for..also check the recording lens and clean with a duster spray..it may be dirty..
Jan 19, 2014 | Tascam BB-1000 Portable CD/SD Recorder
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
All speakers work with dvd but only 2 speakers with tv why is this?
Because the TV is producing Stero L+R (2 spkrs) but the DVD is producing Dolby 5.1 (5 spkrs)
Mar 06, 2011 | Audio Players & Recorders
I HAVE A MULTI-DISC CD PLAYER WITH FUZZY SOUND
Digital or analog output? Try the other - same thing? If it improves by switching outputs, suspect teh cable. Also try moving the output to another input on the receiver (?).
Feb 27, 2010 | Onkyo DX-C390 6-Disc CD Changer
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Laser jet 1600 printer high pitched squeal
It proberly has dust in the printer near the spool (the picture below)
Sep 11, 2009 | HP Hewlett Packard LaserJet 1600 Printer
Humming noise
If this is like my unit it is a high pitched squeal. I received my unit as a gift for Christmas 2007 and I thought it was defective. I contacted Homedics and they sent me a replacement but the problem persisted. As licensed amateur radio operator I am versed in electronics so I decided to track down the source of the noise. It turns out that the 16VDC power adapter is the source of the noise. It is what is called a "switching power supply" and is unfortunately not well filtered causing the high pitched squeal. I was able to get rid of the noise by modifying the power adapter and adding a 2200 microfarad capacitor in parallel with the output. This filters out the high frequency ripple and gets rid of the squeal. An alternative solution would be to search the Internet for a better 16VDC power adapter. It must supply 2 amps of power and have a 5.5mm OD/2.1mm ID center positive power connector.
Nov 09, 2008 | Homedics iSoundSpa Max Clock Radio with...
Audio problem with hitachi 53 inch rear projection t.v.
Good Day, 1bigmoney;
Try resetting the SAT box. To do this unplug box for 2 to 3 minutes then plug A/C cord back in outlet. If no fix have SAT. box replaced, after making sure all cables on BOX are secure.
Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Sony DAV-FC7 System Logo
903 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
