Mother board the mother board when you swicth on power it powers but it can not run its setup or to display on the monitor. i have dry to chenge the comos battery, Ram, Vga card but i have fial to get the problem ply assist me TONNY
  • Anonymous Jan 09, 2009
    Yeup, I have the same issues, no post sounds and no bios read on video display. However, it did fire up and give bios screen and setup options, which I changed the config, but never came up again on full bios boot. I wish I had a manual for the Aopen "s661GXm-U" motherboard.
  • ACC4 Mar 04, 2009
    Computer Lights On, But There Is No Displa, & No Any Error Sound
  • 105 Answers
It is a new feature of motherbaord for self test
Posted on Aug 08, 2008
    Scholar:
  • 176 Answers
What is the motherboard !?
- if it has an incorporated video card, first connect the display to that video output !
- does it make any sounds ?!
- is everything pluged in propperly ?!
- remove the motherboard from the case, and than make all connections in such a way that it does not touch the case - mayby u have a faulty power suplly and shorts the motherboard ...
- and ofecourse , is the display working ? :)-
My computer has no displayed on the monitor but has a power,it's attached to the built-in video card of mother board the model of my mother board is "K7MOS+7.5C" what should i do???...
Hello Wongcarlkley, hi, looks like you have memory module problem, need to clean module contacts using pencil eraser, try this fix first and see if it will solve your problem.
May 05, 2010 | EliteGroup K7SOM Motherboard
Hi Master, can you help me how to fix mag innovision model 468P when i turn on the monitor in a second the monitor will automatically off display and change the light power from green to orange.? please...
from green to amber could be one of many things,1 video grapics card malfunction,,,2,, dry joints in the mother board..3 bad data cable ,,pc to monitor cable vga,,failing power supply,,,,i suggest you open the pc remove the data cable to you floppy while it is off remove memory stick clean with a damp soft rag or tissue reinsert when allowed to dry for 10 mins and then restart pc without the speakers web cam and anything except mouse keyboard and restart ,if it does same thing then your problem lies in *********** board,thus you need a new one
Oct 21, 2009 | Mag Innovision 771fs-s 17" CRT Monitor
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
Compaq Presario v5000 desktop
Is there a power switch on the back of the power supply which is not on? Make sure the power cord is good and plugged into a good power source. Do the fans run inside the system? Is the fan for the power supply working? If not the power supply could be bad. You can purchase a power supply tester to plug the mother board connector into to verify the operation for about $15.00. Do you see any lights on the mother board and the Hard Drive light flickering? If you do and your Key Board lights are on your video controller or monitor could be setup wrong or defective. If the power supply tests good then you need to test the memory and CPU. You could also carefully remove all boards except the video card, mother board and memory and see if it boots up.
Mar 30, 2009 | Compaq Computers & Internet
Problem with toshiba A135-S4527 ,MOTHERBOARD NOT INITIALIZING
I can solve this.
THROW AWAY ******* TOSHIBA BRAND OUT OF UR LIFE
Nov 04, 2008 | Toshiba Satellite 1135-S125 Notebook
Mpga478b
have u check ur memory?... ur videocard and powersupply...thats the main problem of pc if it has no display....just try it one by one...hope it can help u
Sep 10, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
IBM Mother board mlack out
just buy another power supply with a higher power for the problem is not on your computer but on the power supply,then try to plug it in a 220v voltage regulator,but i surely recommend that you'll buy a new power supply ok
Apr 08, 2008 | IBM 486DX 80486 (32G4144) Processor Board
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
369 people viewed this question
David Payne
David Payne
