Question about Cell Phones
As soon as my n95 turns on it freezes and turns off
    Genius:
  • 1,011 Answers
Check if battery is ok. mean Healthy.
if ok then remove it and leave your set without battery for some minutes and try again.
regards,
Posted on Aug 08, 2008
Nokia N95 8G - freezes when you turn it on and you can't go past the NOKIA welcome screen. Tried taking the battery out, charging it, etc.
Just format your phone by the following way
To Format the phone
1)Switch off the phone
2)Hold 3,* and Green button simultaneously
3)Now press the power button holding the 3 button, After 5 seconds leave the 3 buttons
4)You phnoe should say, formatting and all your data would be reset to factory orginal
CAUTION: You will loose all the data and contacts stored in phone memory, But this is the only way
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
Sep 29, 2009 | Nokia N95 Cellular Phone
Nokia N95 8GB , freezes when turned on
I think that maybe the software (symbian S60) may be corrupt on your phone.
Hopefully all of your contacts, etc are backed up as i think you may have to do a hard reset.
To do this type *#7370#.
The phone will re-start and it will be returned to its original factory shipped state.
I hope this helps.
Jul 08, 2009 | Nokia N95 Cellular Phone
My nokia n95 keeps freezing alot keep freezing while using the GPS or sometime w/o any sw running
When you run apps and use web especially when watching online videos, ram of your n95 quickly start ending.When the ram completely finishes, your phone freezes and reboot.So you should continuously clear private data while browsing and don't run more than one software at a time so you can save the ram.
Mar 31, 2009 | Nokia N95 Cellular Phone
Nokia N95 8GB - Freezing up.
Hi greystar,
All I can say is a HARD RESET will solve your problems(and eventually all your problems)!
First backup the important stuff like the contacts, messages, apps, etc. using the Nokia Content Copier available from the Nokia PC Suite.
Then switch off your phone.
Now, press and hold the ' * - Star', '3', & 'Call - The Green key that you use to recieve a call' together and switch on your phone. Keep the above mentioned keys pressed till you see the "Select Region" screen.
Hope that helped! :-)
Regards,
Sam
Nov 30, 2008 | Nokia N95 Cellular Phone
Soft ware problem for nokia 8gb
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details
if you reset,U'L LOSE AL YOUR DATA.
so try this only if you dint find any other way out.
plz dont forget to rate this if this was helpfull..
have a nice day
Oct 14, 2008 | Nokia N95 Cellular Phone
I turn on my n95 and it vibrates the keypad lights up but it will go no further and can only be turned off by removing the battery
My N95 does this too. I have a fix that will turn the phone on properly.
1st take out battery,
2nd press and hold power button,
3rd insert battery while still holding power button,
4th release power button as soon as your phone vibrates.
That works for me.
Aug 24, 2008 | Cell Phones
N95
hi there!
i do have a nokia n95.. but my problem is that im having problems in downloading a theme as well as java games.. what should i do? can somebody help me with this?
May 23, 2008 | Nokia N95 Cellular Phone
Nokia n95 freezing
If your phone used to work but has stopped because it froze and you took the battery out, to restart it. There's a possibility that it will need a reset to get it going again.
Reset code: *#7780#
But if you just got it, and it has never worked, it might be blocked, by the original owner, (who lost the phone or had it stolen), using the
IMEI (International Mobile Equipment Identity)
in which case you need to take it to a repair shop.
Feb 04, 2008 | Nokia N95 Cellular Phone
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Sep 09, 2007 | Nokia N95 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
