Question about Microsoft Xbox 360 Console
New hitachi drive wont play any discs
I recently fixed the 3 red lights and then found the dvd drive could not read any discs, i bought a new hitachi drive of the same make and swapped the chips over(as i dont know the original key) and still it wont read anything
Any ideas, it cant be the laser as its a new drive(with original chip)
    Problem Solver:
  • 14 Answers
Your firmware from the original drive became corrupt,
dig in some of the lead tech/mod forums to see what you can do about that.
Posted on Aug 10, 2008
SOURCE:
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
XPS One will not read CDs or play DVDs
1.use original disc, bcz some brand drives not supported all the discs available in the market.
2.cheak with other disc,if any disc cant read ,then
* Open Your CPU system cabinet,then cheak the data cable and power cable of the Dvd/Cd Drive.(You may change the other power card in your system already had)
* change the data cable
3.if u still have the problem,then finaly replace the new drive.LG Dvd Drive is beswt one.because it can read all discs.
Mar 09, 2010 | Dell XPS One All-in-One TV Desktop with...
It just stop playing my games and movies. keep
Your DVD drive's laser is malfunctioning.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the laser head all together. Replacements can be found on eBay. You can follow this guide to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the original drive's firmware and putting it on the replacement one. The guide for that can be found here.
Dec 06, 2009 | Microsoft Xbox 360 Console
PS3 won't read discs of any kind at all. We have an old PS3 (husband says the biggest one) that was the first kind to come out. Recently we have found that the PS3 no longer reads any of our games or DVDs....
the laser has gone bad in the dvd drive. You can either replace the laser if you know how to get into the dvd drive or just replace the dvd drive itself. You can find them on Ebay at a decent price.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
The problem with my 360 is that I just replaced the piece of junk factory disc drive, it works fine but it wont play games, it brings up a srceen in about 15 languages saying to insert the disc into a 360,...
And your new one should also be (a hitachi ) with
the P.C. board from your old drive instaled in
your new hitachi drive. If that is true then you
need to check all your ribbon conections just
to make sure one didn't slip out on you.
You should not have to adjust anything.
It should WORK.
Rob
Oct 08, 2009 | Microsoft Xbox 360 Console
Dvd drive not reading properly
Have you loaded the dvd drivers to view the dvd's through ? you need something like Cyberlink or Power DVD
Dec 25, 2008 | Medion (40002895) CD-RW/DVD-ROM (Combo)...
Unreadable disc
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Aug 26, 2008 | Microsoft Xbox 360 Console
Xbox 360 disc drive
To april23
what has most likely happened is that the magnet which holds disks in place has dis-lodged and is now stuck to the roof of the dvd drive. Unfortunately the only way to resolve this would be to open up the xbox 360 and open up the dvd drive to fix.
So if you're not confident at this or in doubt in any way I'd contact Microsoft first if it's still under warranty, if not then it's a case of opening up the drive yourself I'm afraid.
Note. Does the drive attempt to spin up when you put a disk in?
Or does it just make small noises then nothing except "open tray" on screen?
Oct 07, 2007 | Microsoft Xbox 360 Console
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
Can I playback my movies on a DVD-ROM drive?
No, DVD-RAM disc recorded on the DVD Camcorder will not play back on every drive. Some of the new DVD-ROM drives designed to be compliant with the new DVD-RAM book2 standards will playback discs recorded on the DVD Camcorder. Many previous DVD-ROM drives on the market that came out before the DVD-RAM standard was released will not play back discs recorded on the DVD Camcorder. HITACHI manufactures DVD-ROM drives for some PC manufactures as OEM products. HITACHI model GD-7500 DVD-ROM has DVD-RAM read/write compatibility.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
