Question about Dell Dimension 8300 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
Dell Dimension 8300 flashing amber power light, PC is dead, Green MB light is steady, no diagnostic lights. Replaced power supply per dell tech notes and still have same problem. When first plug in, main fan "jumps" once then all quiet.
  • 1 more comment
  • CHALET13 Aug 08, 2008
    Sounds like time to toss it. Had suggestion to go bare-bone and keep what I can. Thanks
  • db5976 Dec 05, 2008
    Sometimes it starts up as normal, but most of the time the light blinks amber. Is it the mother board, power supply or both?
  • Anonymous Apr 04, 2009
    I have the exact same problem, sometimes the PC used to boot but latel it simply doesn't anymore. The Amber power light keeps flashing, the internal Motherboard light is green indicating it has power, but everything else is dead.
    Master:
  • 397 Answers
If you want to repair your Dell you can get Dell motherboards from here at reasonable prices:
http://www.ascendtech.us/index.asp?FSCat=303&url=IND&iFromFeatured=1
I have bought a lot of Dell motherboards from here and never had a problem.
They list a mobo for your machine but the price is a bit salty at $149.99
Posted on Aug 08, 2008
    Genius:
  • 2,785 Answers
It seems *********** board is having problem plz send it for servicing
SOURCE:
Dell xps gen 4 diagnostic lights A C D green B amber also front power light is flashing green and amber
go to dell website and see what those lights are meaning, I can't help with no exact brand and model (Dell - model ....)
Feb 19, 2014 | Dell Dimension XPS Gen 4 PC Desktop
Blinking amber light on the on/off button.
No light : The computer is turned off (S4, S5, or mechanical OFF)
Steady green :The computer is in a normal operating state
Blinking green : The computer is in a power-saving state (S1 or S3)
Blinking or solid amber See "Power Problems"
check power
Sep 06, 2011 | Dell Dimension 4300 PC Desktop
Power light is blinking green and amber
my power light flashes green/ amber as soon as it is plugged in, with a dead battery. It seems to go to steady amber if the plug is tapped, but goes back to flashing. It will not hold a charge on a new battery.
Dec 28, 2010 | Dell Axim X51v Pocket PC
No power on dell e520 dimension
On the 20 pin connector, short the green wire to any black wire with a paperclip. This will force the power supply to turn on manually if the motherboard is not giving the correct "ON" signal.
Feb 26, 2010 | Dell Dimension E520 PC Desktop
Dell Dimension 2400 with steady amber power light and diagnostic lights of ABC green and D off. What could be the problem?
Steady amber power LED is indicative of a problem with the motherboard. Remove all external connections except power, remove all PCI Cards, ram, disconnect power from all drives, turn on see if power LED is still steady amber. If it is, more than likely the motherboard has a failure. Also check to see if the CPU heatsink is firmly seated (The plastic retainer has been known to fail causing the CPU to overheat)
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 9200. Having a problem with power to PC. The power supply unit is working fine. The power switch seems to be ok, but the machine will not power up. Do you have any suggestions
Please check on the power button if the Led is steady amber it requires motherboard replacement. If the light is steady green check the cables in the system that they are connected properly.
Jul 11, 2009 | Dell Dimension 9200 PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Windows XP won't start
The amber light is the error light on a Dell. It can mean a few things. 1. RAM has went bad, not properly seated. 2. Video card has went bad or come unseated. 3. Power supply is not working properly; or 4. Motherboard has went bad. Hope this helps & please remember to rate my answer.
Jan 02, 2009 | Dell Dimension 2350 PC Desktop
Dell Dimension 8300 PC Desktop Logo
1,821 people viewed this question
Ekse
Clive
Clive
