Question about Durabrand DUR7 Portable DVD Player
The DVD Player doesn't power up
I believe the receiving post (inside the dvd) for the charge is broken. Can something like this be repaired.
The unit is made by venturer go
www.venturersupport.com
Posted on Aug 08, 2008
Power light blinking on sony dvd player
Repair of a portable unit with a power supply problem inside it is likely not to be economical and parts for these units are rarely available.
No magic wand for this issue--unless was a very expensive unit replace it--
May 02, 2012 | Sony DVP-FX930 Portable DVD Player
My DVD/VCR player does not receive power what is wrong and can I get it fixed? The power cord has not cuts, I have tried multiple outlets and still nothing
have you checked to see the prongs/ground aren't loose or broken off?
The cord might be bad, or the power converter inside could be bad. do any lights come on at all?
Aug 09, 2009 | Samsung DVD-V4600 DVD Player/VCR
Broken power jack
If it's shoved all the way in and was connected to the pc board inside the unit you will probably need to buy another one. The only way to fix this is to open the unit up and repair the jack.
May 31, 2009 | Cyberhome CH-LDV1010RS Portable DVD Player
I have a DVD player, VCR player, TV all attached to an RCA RT2250 audio/video receiver. All was just fine until 2 days ago when the DVD player would no longer give sound and icons of the speaker system...
It's possibly only needs soldering of the voltage regulators. they are on the main circuit board heat sink (middle of the receiver and can be accessed by the bottom panel.
JohnW
Dec 21, 2008 | RCA RT2250 System
Blew up something
You must have used a charger that has too much voltage and current delivery. You overloaded the power supply circuits and what you heard blowing up was a capacitor. This is a repairable problem. You must open up the dvd player and see how much damage was done. You can try to replace a few parts that will appear damaged and get a correct voltage adaptor and see if it works. Most likely though you have damaged the player beyond repair. Sorry to give you the bad news. If it is that damaged you should just buy a new dvd player. The cost of the repair and findign the parts will be a lot more expensive than buying a new player. I hope this information help you with your problem.
Oct 11, 2008 | Mintek MDP-1810 Portable DVD Player
Battery won't charge
Borrow or get a cheap volt meter to see if the power supply is working. Insert one probe on the inside, and one on the outside to see what is going on inside the power supply/charger.
Does the power supply hum or get warm? If not, it was probably made pre-broken at the factory in china. Either that or it's power lead has a break, it's power output jack or where it connects to the main board on your portable DVD player.
-Pro Hack
Aug 13, 2008 | TruTech PVS12701 Portable DVD Player
Rechargeable Battery Pack
I need help for my DVD plaer. The battery pack is not charging. Help. Help.
Aug 02, 2008 | Protron PDV-228 Portable DVD Player
Sony
The protect message indicates that a problem was deteceted inside the machine. normally this means that the output amp has a problem. Please post the model number of the receiver or amplifier and I'll post additional details. Also, this problem is currently listed under DVD players. I believe that this should be under receivers. If you can, please move this discussion to the correct category.
Thanks,
Dan
Mar 02, 2008 | Sony DVP-S330 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Durabrand DUR7 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
