Washing machine Hi, i can't get my washing machine door to open. i have tried everything i.e turn it off do a complete wash again, even had sopme look at it but he says cant do anything without the man ual. but i don't have the manual. Can you please please help me resolve the problem. product: LG intellowasher WM-1460FHD Washing Mahine
  • Indi Singh Aug 08, 2008
    what website can i download the manual from ?
Posted on Aug 08, 2008
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
The machine door wont open after it finish the wash cycle
There should be a LOCK ICON with an LED to tell you whether the Front Load door is locked or unlocked.
If the machine door wont open after the wash cycle, the dryer function or the drainage function hasnt completed.
What you can try is just choose the dryer function after the completed wash cycle if the problem arises again.
IF that doesnt work, then look at bottom of the machine; there should be a flap present which you generally open up to get to the manual drainage valve.. you just pull that open and drain any leftover water .. After the water recedes.. the LOCK icon should be off and you can then open the front load door
Dec 07, 2014 | Indesit W 123 Front Load Washer
LG frontloader WD-1238c door locked
Unfortunately it as to be open from top take power off open top normally two screws at the back slide cover off look inside front loader for door catch unscrew and done open door replace with new one same model connect wires as disconnected take pics before disconnect screw it back on done.hope it helps you
Jan 10, 2018 | Washing Machines
I have a Samsung Eco-bubble 8kg washing machine. And the problem withthis machine is that after completing washing, the door is not unlocked. I have tried to make another washing operation so that maybe it...
Mine does this when the filter is blocked. (SE) on the light indicator. Switch it off at the wall for 5 mins. Turn back on at the wall and after 20-30secs you will hear a click. Open the door. When you turn the machine on with the on/off switch, the door will lock again. Run through a quick wash. Hope this helps someone :)
Aug 21, 2011 | Washing Machines
My haier new washing machine washing and completes all cycles, but the door will not open, i have checked the filter and tried all the cycles yet it still wont open ive even tried turn the machine off at...
It sounds like the door lock has failed.
Call the seller before you do anything as you don't want to invalidate the warranty. You may be able to remove the top of the machine and defeat the interlock which is preventing the door opening from the inside.(REMOVE POWER FIRST)
Mar 05, 2011 | Haier Washing Machines
LG Tromm Front door won't unlock
I have this exact problem!!! Did anyone ever figure it out??!! HELP!!
Jul 27, 2009 | LG Washing Machines
Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Jan 01, 2008 | Washing Machines
Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Dec 08, 2007 | Maytag MAH8700A Front Load Washer
I'm afraid I don't have a solution, just the same problem. Exactly this has just happened to me and I don't know what to do. Calling out an engineer will be too expensive and in the mean time, I can't do any washing. Have you had any success yet?
Jun 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
