Question about HP Office Equipment & Supplies
I have an HP LaserJet 4050 and it needs perform printer maintenance. what should i do
  • 446 Answers
It means it is time to do some preventive maintenance on your unit, or keeping the print heads clean
It is important you keep the printer heads clean. This stops ink clogging the nozzles of the printer, and reduces ink smudge on the paper. This is important for HP , as they don’t always do the best automatic clean in my experience.
To clean the print heads, remove the cartridge, and gently clean the print heads with a soft cotton cloth dipped in a little water. I wouldn’t recommend using tissue or alcohol. Be warned!
Make sure the print heads are dry and then replace the cartridge. By doing this you will expand your printer life and the quality of the printouts.
Prevent the printer from drying up ink by using it
I remember taking support calls around a year ago. People would say I haven’t used the printer for over a year, and the quality isn’t what I expected.
If you use your printer regular this will prevent ink drying up and keep the printer and ink in good condition. Use both Colour and black and white prints weekly to stop the nozzles on your printer getting clogged up, or the ink to simply dry up. Be careful with printer jams Don’t ram the paper out if you have a paper jam. This can damage the printer, which I have seen done many times. Look at guides on the manufactures site, if you don’t have time to do that, remember that you want to get the paper out smoothly. Most HP Printers have a hatch attached at the back that can be removed. You will then have access to the paper wheels, and you should be able to see the paper that is jammed in there. Remove the paper this way, and it is unlikely that you will damage the printer. Power down correctly Turn your printer off when not in use. This can prevent drying of ink and also help keep the printer functioning at high quality. Remember to use the printers power button, and them remove at the plug if need be. Don’t power off if you are in the middle of something. These will just cause problems for you. Clean your printer but don’t over do it IF you perform print ink clean by software or your printer’s hardware, do it once and not over and over. Doing this over and over can cause more damage than good. Clean your printer’s encoder strip monthly to stop quality issues at a later date. Remember if you have low ink to replace immediately. This prevents ink being left in the printer heads and nozzles, and will generally give your printer more life.
hope this helps you, dont forget to mark my solution pls.
Posted on Aug 08, 2008
  • 34 Answers
Wait a minute...you said HP 4050, right? A 4050 is a laser jet and does not use any kind of ink. It only uses toner. There are no print heads. There is no "ink clean" process, etc.
Your solution is simple. Purchase a maintenance kit which has all rollers and a fusing assembly. This is VERY easy to do. If you go that route, chime in and I will tell you how to do it.
In the event you do not want to spend money, you can kill the message, but the PERFORM USER MAINTENANCE message is only a counter. You now have 200,000 copies on your printer. Conservative move is to replace the fusing assembly cause if you dont your print will start to go downhill either now or later.
I have seen fusers die before the message, and I have seen them last long after the message.
Posted on Mar 16, 2009
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
HP Laserjet 4050. Can I connect from my TCP/IP to JetDirect?
To use a printer DIRECTLY into your PC or laptop (without plugging both into a network hib, or switch), you need to use a CROSSOVER patch cable.
Feb 19, 2010 | HP LaserJet 4050 Printer
How do I download a drive for my laserjet 4050? I
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=18322&prodTypeId=18972&prodSeriesId=25475&swLang=8&taskId=135&swEnvOID=228
Aug 23, 2009 | HP LaserJet 4050 Printer
Hp laserjet printer cleaning and maintenance
Take the toner cartridge out and turn it upside down and look at the drum. It should be clean if the cartridge is not leaking.
Jun 14, 2009 | HP LaserJet 4050 Printer
PERFORMING MAINTENANCE ON HP LASER JET 4050
I do recommend a maint. kit ( p/n # C4118A). to clear the maint. messsage, turn the printer on while holding down the left item and left -value key, when you see reset maint. let go of the keys..
Mar 29, 2009 | HP OfficeJet J4580 All-In-One Laser...
Separation pad for HP LaserJet 4050
Open tray 1
remove the pick up roller
pad is located under the roller
in the front center of the pad is a small notch
inset a small screwdriver or key something small and flat.
give it a twist and the pad should pop out.
install the new pad by aligning with the holes and push down should sort of snap into place.
Reinstall pick up roller
Hope this helps
Mar 25, 2009 | HP LaserJet 4050 Printer
MY PRINTER WILL NOT PRINT OUT
check and see if the computer actually recognises the printer. go into printer settings and see if your printer is listed. if not click on install printer.
Jan 12, 2009 | HP LaserJet 4050 Printer
HP Laserjet 4050 hangs on processing job
Unplug printer cable.
turn off
turn back on and wait for READY
turn off
connect printer cable
turn on
Jan 05, 2009 | HP LaserJet 4050 Printer
265 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
