Question about Foxconn 761GXK8MBRS AMD Athlon 64/Athlon 64 FX, Socket 939 (939-pin), 1600/2000MT/s SiS761GX + 965L... Motherboard
PS/2 Keyboard not Working
I just had a 761GXK8MB (with Athlon 64-bit CPU and new power supply) installed into a Dell Dimension chassis. I tried using a PS/2 keyboard (two different ones) along with serial or USB mouse, and it would hang up (or delay a long time) in POST whenever I kept the PS/2 keyboard plugged in and pressed keys. Even if it booted I could not use the keyboard in Windows. I finally had to buy a USB keyboard as solution. I checked BIOS Setup and didn't see anything I thought would cause this behavior. Why would the PS/2 keyboard not work?
  • jdnimrod Aug 11, 2008
    I don't mean to be contrary, but doesn't the Super I/O contain the PS/2 controller and the "south bridge" contain the USB controller? I'm not sure how the north bridge would cause this, so please elaborate. I thought it might be more likely a problem with BIOS settings, or maybe a bad solder joint on the PS/2 connector.
  • 84 Answers
Ps/2 means the north bridge chipset is going ( just not totaly dead though ) in time you may notice the usb may not work at 2.0 speeds
Sorry nobody on this planet can repair a ps/2 unless another motherboard is purchased .
Posted on Aug 08, 2008
1. Can Dell Dimension 9100 work with 2x2gb ram? 2. I am trying to install Windows 7 on a refurbished Dell Dimension 9100. It has 2x2gb ram, 1 TB Hard Drive and I have Windows 7 32 and 64 bits + Palit...
Here is a link for upgrading to Win 7: http://en.community.dell.com/support-forums/desktop/f/3514/t/19356108.aspx
If you can't boot form the CD/DVD you have a problem with your CD/DVD drive. If you can enter the BOIS (setup menu) then your computer is working, just waiting for a device to boot from.
Mar 20, 2011 | Dell Dimension 9100 PC Desktop
Hello, i have amd athlon 3.0 ghz 2gb system. i want to install windows 7 64 bit. and i llike gaming too.... i have nvidia gforce 9400gt 1gb. 1) so can i add more ram virtually for 64 bit??? 2) will...
if you have windows already installed you can use the upgrade advisor and that will tell you what programs will be affected http://www.microsoft.com/windows/windows-7/get/upgrade-advisor.aspx
Mar 11, 2011 | Microsoft Windows XP Professional for PC
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
I have at current a AMD sempron 3400+1.80GHz processor,socket AM2(940)core VID 1.100V,core speed 1002.2 MHz,bus speed 200.4MHz,HT link 801.7 MHz,stepping 2,L1 data and inst 64 KBytes-2-way,level 2 256...
The main thing is before you go swapping cpu there are some things to consider. 1. the new processor may draw more power than your current power supply can push out. 2. it will probably generate a lot more heat...both are bad..
But if you insist you can get away with an Athlon 64 X2 5600 or 6000+ cpu be careful though because some have different voltages which may not work with your board.
hope that helps.
Feb 03, 2010 | Dell Dimension C521 PC Desktop
For 3 weeks My Dell 4700C had difficulty starting. It took from 3-6 attempts to start. In the 3rd week the fan began to sound like a plane starting up. It would get louder and louder until I thought it...
hi have you heard any beeps when pc starts they tell you whats going on 1 beep all good and so on what ive found over the years is some times things need to be reseated turn pc off unplug try to start to drain power touch psu with hand on metal to earth then take ram out and reseat it same as batt take out try to start with no pwer to drain board again but in go in to bios change any setting like which hard drive you want to start first tell me how that goes cheers mate ps i never heard of cpu being limited by ram its you motherboard and os system which deside how much ram you pc can handle 32bit can read 4 gigs 64 bit over 12gigs
Oct 17, 2009 | Dell Dimension 4700 PC Desktop
I need help upgrading PLZ URGENT dell dimension E521
The most powerful CPU Dell sole in the E521 was the 5600+, 2.8G, Pretty Cheap on EBay
http://shop.ebay.com/i.html?_nkw=Athlon+5600%2B&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Athlon%2C+5600%2B%2C+2.8G%2C+1MX2%2C+Dual+Core%2C&_osacat=0
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150369
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
Oct 08, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Noisy fan
Usually the heat sensor on either the CPU or the mother board through the BIOS software ajusts the sped of the van. Are you talking about the CPU fan , The Main case fan or the power supply one?
Feb 28, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
My system shows long beep
with the computer off unplug the key board and then plug it back in. Restart the cpu and should work if not re- install software, if that dosn't work try a new keyboard
May 15, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Foxconn 761GXK8MBRS AMD Athlon 64/Athlon 64 FX, Socket 939 (939-pin), 1600/2000MT/s SiS761GX + 965L... Motherboard Logo
236 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
