Question about Samsung CLX-2160N All-In-One Printer
Imaging unit my printer keeps prompting me to install the imaging unit even though it's a new one, why?
  • Samsung Master
  • 4,338 Answers
Is it a genuine Samsung Imaging Unit? The unit is not seeing it as such.
This is the # for it, CLP-R300A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 22, 2008
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
Image cycle
if you use toner that says for use in instead of Kyocera brand toner this can happen you have to remove all the toner in the dv unit and install only Kyocera toner when you do that enter 1087 1087 then 130 and let it run until its done this will refill the dv unit with toner even though you have a copystar machine its made by Kyocera when it stops enter 01 then print to return to normal operating mode
May 07, 2014 | Copystar - CS-3035 Printer
How do i change printer cartridges ?
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2
Lift the scanner unit or access door (per right-hand image).
The cartridge holder will move to the center of the Inkjet or All-In-One.
pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. pattlnk_1202009_209-hw_cartridge_carrier_lids_p.gif 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5
Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges. pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge. pattlnk_1202009_2024-color_install.gif 6b The image at right illustrates inserting the black cartridge. pattlnk_1202009_2016-black_install.gif 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image.
Mar 31, 2011 | Lexmark P4350 All-In-One InkJet Printer
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
Brother Fax MFC 790CW. Loaded the USB cable from fax machine to my computer and start with it would print from the computer though now it keeps saying offline all the time and even though when I right...
Hi there Jenny, are you using Vista with this printer? If yes, you can to the following:
1. Click the Vista Start button, and go to Control Panel
2. Click Hardware and Sound.
3. Under Printers, c
lick Change default printer.
4. Right click on the printer icon, select Run as administrator, and then click on Properties.
5.
If the User Account Control prompt is displayed, click Continue.
6.
Click on the Ports tab.
7.
Click Configure Port associated to your Brother MFC790c
8. Change the Protocol to Raw.
9. Then click OK.
Restart the printer and try again.
If this does not work, please let me know so that I can suggest other solutions. Goodluck!
Oct 25, 2009 | Brother Office Equipment & Supplies
Alignment problem- says to remove tape from cartridges, not sure what tape or what cartridges.
Did you recently install new ink cartridges?
See below, or go here and enter your model # , choose tech support and search "change print cartridge" for detailed instructions with pictures.
Overview
This article provides general instructions on how to change the cartridges on Lexmark Inkjet and All-In-One printers.
Procedure
2 Lift the scanner unit or access door (per right-hand image).
5 Remove the protective tape from the back and bottom of the new cartridge(s).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers ID: ENUS32244 Overview
Procedure
NOTE: These instructions are general, and your specific Inkjet or All-In-One may appear different than the pictures below; however, the steps are the same.
Step Action Image 1 Ensure the All-In-One printer is powered on. No image. 2 Lift the scanner unit or access door (per right-hand image).
pattlnk_3232007_1123-01%20open%20scanner%20unit.jpg 3 Press down on the cartridge carrier latch to raise the carrier lid. pattlnk_1202009_209-hw_cartridge_carrier_lids_p.gif 4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge. No image. 5 Remove the protective tape from the back and bottom of the new cartridge(s).
pattlnk_1202009_2013-remove_tape.gif 6a Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge. pattlnk_1202009_2024-color_install.gif 6b The image at right illustrates inserting the black cartridge. pattlnk_1202009_2016-black_install.gif 7 Close the carrier lids so that they remain closed. See image above in Step 3. No image. 8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed. No image. 9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job. No image. Still Need Help? If you require additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need the machine/model type and serial number (SN) of your printer.
Please call from near the computer and printer in case the technician asks you to perform a task on one or both of these devices.
Jul 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Doesn't scan. Only print and copy. Say's no USB
Usually the scanner and printer have separate drivers, even though both are included in one machine.
Check HP's website to see if there's a separate driver for the scanner or a program which installs both drivers from the same setup program. You might have to check device manager to see if a scanner is listed and if the driver is properly installed.
In XP and VISTA, go to control panel/device manager and see if there are any yellow caution signs by the 'imaging device' icon. If there is no 'imaging device' icon, either the driver is not installed or not installed properly.
One additional factor... HP usually requires that the driver be installed before the hardware is connected. After drivers are installed, New Hardware Wizard should find your HP devices and install them properly. If not, you might want to unistall them altogether and reinstall.
Hope this helps.
Jun 15, 2009 | HP PhotoSmart C4280 Laser Printer
Wasn't prompted to load image disc print shop pro deluxe 23
just go to control panel, add remove programs, select print shop (change) and select modify it will allow you to change content to hard drive and not cd.
Mar 19, 2009 | Broderbund PrintShop Pro Publisher Deluxe...
Samsung CLX-2160N All-In-One Printer Logo
473 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
