Question about Canon PowerShot A80 Digital Camera
Not working My camera won't turn on when the memory card is installed. When I take out the card the camera turns on but, it says no memory card. How can I fix this?
  • sammisgee Aug 27, 2008
    I have already done that. Thanks anyway
  • Canon Master
  • 4,738 Answers
More than likely you have a bent pin in the card slot. Remove the card and look inside the card slot. If you notice any bent pins, remove the camera's batteries, then attempt to straighten the bent pin using a small/skinny jewelers screwdriver (you can get a jewelers kit from most dollar store tools sections).
Just bend the pin back as best that you can, it doesn't have to be perfect. Once there, SLOWLY reinsert the CF card. The card itself will fine-align the bent pin. If any resistance is encountered, immediately stop as the pin is not straight enough. Try straightening the pin again and repeat the insertion until the card goes in without resistance.
Posted on Sep 03, 2008
  • 797 Answers
Try a different memory card. Some of these cameras may not support large sizes. Try a smaller card such as a 512 or a 128.
Posted on Aug 24, 2008
  • Dave Lundmark
    Dave Lundmark Aug 27, 2008
    If you have tried another card, and it still does not work, then try the following.
    Start the camera and go to the menu where you can RESET ALL.
    That will reset all settings in the "bios" of the camera. If it still does not work, then it needs repair, or sell for parts or as is on a site like Ebay.
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Posted on Jan 13, 2008
RadarRon
  • 398 Answers
SOURCE: Memory Card Error
Chances are that the contacts in the card slot are either dirty or worn out. First thing I would try would be to try blow out the card slot. I suggest caned air, You could use a straw and Puffs of breath, but keep it dry. If that doesn’t work put a lint free cloth over a piece of cardboard about the same size as a memory stick. Be vary careful that it is not thicker then the memory stick. Dampen the end with Alcohol (Denatured Alcohol is best but standard rubbing alcohol might work in a pinch). I repeat, dampen with alcohol not dripping wet. Remove the battery just to be sure. Insert the swab into the card slot a half of a dozen times when you pull it out look to see if you see any residue on the swab. Hopefully you see dark stripes on the cloth. Let the camera sit with an empty slot (and no battery) for a hour before you try it again.
If all that fails the last chance (short of replacing the card reader) try to put some electrical tape on the memory stick on the side opposite from the gold contacts, be carful not to cover the contacts. Try one piece of type at a time and DON’T force the memory stick into the slot This will slightly increase the pressure on the contacts inside the card reader slot. If you have to resort to this be carful that the tape sticks completely and that it is neatly trimmed, you don’t want the type coming off inside the cameras. If this works you will need to add tape to all memory sticks used in this camera. I would NOT use any “taped” sticks in any other readers without removing the tape first.
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: my camera doesnt turn on
z60...it may be an issue with the motherboard. Easiest way to find out...remove the card and battery. Let the camera sit overnight. Before placing the card and battery back in it....press the power button and hold it down for 15 seconds. Release it...put battery and card back in. If that doesn't fix it...you have serious problems.
Posted on Dec 09, 2008
t00nz
  • 4738 Answers
SOURCE: S400 memory card error
The internal BIOS battery has run down and is causing this error. Don't attempt to fix this yourself. Canon will fix this for you for free, with free shipping, regardless of your camera's warranty status. See and print out the following advisory:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8777&keycode=2112&id=27465
Posted on Feb 22, 2009
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 5100 Digital Camera
Fujifilm xp30 that won't turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Dec 16, 2011 | FUJIFILM FinePix XP30 Digital Camera
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
Aug 25, 2011 | HP Photosmart M415 Digital Camera
No disk installer and memory card wont work
The 8025 doesn't have much internal memory. Without a memory card you can take a test photo but it will disappear when you turn off the camera. You REALLY do need to insert a memory card (SD or SDHC, up to 8GB in size) and format it in the camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 30, 2010 | Vivitar ViviCam 8025 Digital Camera
I have Kodak EasyShere V1223 It won,t Turn on, Go
Here are the steps for V1223 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 17, 2010 | Kodak EasyShare One Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
    • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
    • If the is not resolved , continue with the next step.
    Step two: Check for damage or corrosion on the batteries
    1. Open the Battery/Memory card door on the camera.
    2. Remove the batteries.
    3. If the batteries are damaged or show corrosion, replace the batteries.
    Step three: Recharge the batteries
    1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
    2. Try turning the camera on after the batteries are fully charged or have been replaced.
    Step four: Ensure the batteries are installed correctly
    1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
    2. Try turning the camera on.
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
      WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Canon PowerShot A80 Digital Camera Logo
230 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
