Question about Sony Playstation 3 (PS3) Console
Cant get online
It does the scan but comes bak with cannot find servers message....im using a normal wired modem, not wireless
  • corpzombie May 11, 2010
    Is the PS3 directly connected to your router using a network cable?
  • Alexander Kogl May 11, 2010
    What servers are you looking for?
    Have you tried online gaming?
Im using a wireless modem, i keep getting cannot find server everytime i try to connect...how can i fix this problem?
Posted on Nov 15, 2008
Why does it keep timing me out on gta5 while online?
Matthew, check your NAT type. For live games like GTA5, it needs to be set to "open" If it's type 2 then media is being sent, but blocked when coming in. Limited communication with the servers. It's usually caused by the wrong settings over a wireless connection. If you use a cat5 "hard wire" from your modem directly to your system, it should report back "open"
Aug 21, 2015 | Sony PlayStation Portable (PSP) Console
When I run the set up wizard for my Linkksys WRT160N V3 router, I get the message "Cisco Setup Wizard requires that one wired network adapter be enabled. Error 314: Could Not Disable Wireless...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 04, 2010 | Linksys WRT160N Wireless Router
Im from d Philippines, im currently seting up my Linksys wireless-G WRT54G Router, after entering the password it says "Setting up router" then the next message would be "checking internet connections" and...
Jul 20, 2010 | Linksys Wireless-G WRT54G Router
Hi, Im getting a message that there could be problems with my network adapters so I cant access the internet, what should I do?
Hi, Unplug your Modem/Router for 10 seconds, let it start up, if this doesnt work try using an Ethernet cable and plug it in directly (Wired). let me know, thanks. Mark
May 03, 2010 | Toshiba Computers & Internet
Dlink setup wizard problem
Apr 16, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a wireless broadband router (802.11g) and as im trying to install it, it comes up with the message "there was an error reading the configuation file." please help.. all my connections are good.. i...
First make sure that the computer is able to go online when connected directly to the modem.
Once you are online with the modem , you can try to set up the router manually without the set up disc.
Click Here for step by step solutions
Nov 07, 2009 | Arris WA840GP 802.11g/b (51807400100)...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can't even connect to "setup assistant"
it sounds like you need to keep using your usb modem to connect to the internet. then setup internet sharing on the computer and connect the wireless router to the network plug on the computer.....
then basically you are sharing the internet to the plug on the back of the pc into the router and then wirelessly out to the network and PS3
Aug 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Using a Mobile broadband service for online use.
Im very possitive you cant do that the ones you can do it with normal wireless broadband boxes (wi fi) you can use this wireless by going to your network settings and put wireless (also wired you choice) and then it will tell you to fill some things out with the internet cable with a wireless broadband you can wire it but the connection is better but that depends on how or were u use it wireless is still very very good for more questions (DGKME@yahoo.com) also myspace.
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Cant take apart packard bell imedia to install pci card
when disassembling server chasis, you will have to release the front panel first, only then you can remove the side panel
Jan 03, 2008 | Packard Bell (090317) Modem
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
