Seagate Barracuda ST3250824A (ST3250824A20PK) 250 GB Hard Drive Logo
Posted on Feb 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seagate driver doesn't show up in hard disk list
It shows up in "disk management " as Unallocated and say it's working properly but does not show up in "my computer" as a hard disk device.
and my original drive will soon be too full.
Please Help me to get this second drive working
I'm using XP
Thanks,
Jeff
mrboosh
Level 2:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 77 Answers
  • Posted on Feb 08, 2018
mrboosh
Expert
Level 2:
Greenhorn:
Answers
77
Questions
0
Helped
18175
Points
219
Are you able to see the drive here in disk management?
seagate driver doesn't show up in hard disk list - capture-zgoyxsl3jevnluavvt131fnj-2-0.png If so you can right click on the drive and create a new volume and take all the default setting.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Jul 19, 2007
SOURCE: Seagate hard drive
Is this internal or external drive?
Anonymous
  • 32281 Answers
  • Posted on Jan 10, 2009
SOURCE: I reformatted my C: drive
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Anonymous
  • Posted on Mar 12, 2009
SOURCE: disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Anonymous
  • Posted on Jul 24, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Anonymous
  • 6831 Answers
  • Posted on Sep 27, 2010
SOURCE: external drive not listed in my computer
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
I have a SeaGate FreeAgent GoFlex 500Gb external hard dish and its shows only 230Gb.I formatted it many a times but still shows 230Gb... Please help me to fix the problem..
If you're using windows 7, right click on my computer and choose "manage" then "disk management". There, you should see your external HDD. If it is indeed a 500GB HDD and assuming it is registered as D:, you should expect to see something like (D:) 230GB and 270GB unallocated on one of the disks.
If that's the case, you can go to D:, right click and choose extend volume. Then you can extend it up to the total storage available
Good luck hope this help
I have 3 Rocketpods and they don't work on Windows 7. Built circa 2004. Now what. Can't find a driver suitable with plug and play. Thanks.
If it doesn't show up in my computer but does show up in the device manager Right-click on My Computer. Select Manage in the pop-up menu. In the Computer Management window, select Storage, then select Disk Management. In the Disk Management window, you should see a list of available storage devices. Look for the Disk that has a capacity closest to your Drive. Right-click on the right-hand box; in the pop-up menu select Delete Partition. Once you do this, it will say "Online" & "Unallocated". Right-click on the box and select Create New Partition in the pop-up menu. When the Partition Wizard appears, select Primary Partition and click on Next. You will see a default value for the Drive; click Next. You will then see a drive letter (you can change this drive letter if you wish); click Next. You will then be asked to format the Drive.
Seagate freeagent USB hard drive power is not showing. Adaptor is ok.
if windows then go to
Start->, select My Computer, and rightclick, and choose Manage.
now on the left there is disk manager - click it. if the disk is on the list it is working and might just need to be formatet or activated.
Disk Manager: http://www.partition-tool.com/images/resource/windows-7-disk-management2-b.gif
2answers
I have an Acer 3002LCi laptop. I upgraded the RAM to the maximum 2GB. I also installed a WD Scorpio Blue PATA 250GB HDD. I installed Windows 7 from disk and computer shows drives C and D but drive C...
Install a partition manager program like
http://www.partition-tool.com/personal.htm
open it and you will see the entire hard disk. In there either create another partition in the unallocated space or add it to the D partition.
I cannot see my 'Seagate Expansion 640 GB USB 2.0 Portable External Hard Drive' listed in 'My Computer' as an option. I need to backup files and cannot drag them to the external hard drive since it does...
Hello, if the drive is new it may just need to be formatted, if it's an existing drive it may have a failed partition.
If it's new, connect it to the computer, right-click on your My Computer or Computer icon and left-click manage. When the management console opens left-click Disk Management, then scroll through the right panel and find your 640GB drive. As long as it's there and unallocated you can right click on the unallocated space and select format. Follow the wizard using the default settings. When you're finished it should show up in My Computer.
If this is an existing drive and has failed, proceed to the management console and see if it shows up, if it does make note of all information show in the right panel and either way report back for further assistance by reply to this response.
Hope this helps FixYa,
Chris
Wont show up on my computer
Firstly, make sure that all the cables are plugged in properly for power and USB data transfer. If it still doesn't show up after a few minutes, then Right-Click on My Computer (Vista & Win7 users will see it labeled Computer), then choose Manage, then choose Storage, Then Disk Managment. It will take a few seconds for your computer to fully load in the screen. At the top it should list your hard drive or hard drive partitions if you have more than one partition. Under that you will see Disk 0, Disk 1, and so on. Do you see any of these with a long black bar to the right of it with it labeled Unallocated Space inside the box area under the black bar? If not, then there is something severely wrong with your My Book or the power or USB cables to it, or your computer's USB port is burned out, try all of your USB ports just to be sure. If you do see a long black bar that says Unallocated Space underneath it, then this is likely your My Book. Unallocated Space means that the hard drive hasn't been formatted yet, or that it's partition has somehow been deleted. If you've used this external hard drive in the past to back things up on, then your data is lost because data can't be stored or retained on a hard drive that isn't formatted or partitioned. Be sure that the area of Unallocated Space is actually your My Book. It should show how much Unallocated Space there is, and your's should be reading between 300GB - 320GB. To get your computer to recognize your hard drive you will have to partition and format it. Right-click in the white area under the black bar and choose Create Simple Volume. Follow the steps thru and format the hard drive. After its formatted it should be recognized by your computer again.
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Seagate 500gb hard disk
try going to your control panel/administrator tools then computer managment, look on the disk managment under storage. you might have to set it up in there or asign a drive letter to it.
hope it helps
Firewire/USB 2.0 both dont work..
Plug in the device( kmake sure hard drive is connected inside) Go to computer management(right click on my computer and select manage) on the left pane select disk management on the right pane you'll see the drives(If a screen pops up saying about initialize disks, then proceed with that) in the right pane if you see any unallocated volumes(big black box, full black) with the same size of your disks then you can right click on em and create a partition! The Create partition comes up and give you options to format and everything, after that completes you'll see the drive in My computer! If you don't see the unallocated drive, then go oer the drive and account for all of em, if there an extra one without a drive letter then that could be your disk! If you have any problems or this isn't the problem, please let me know! regards, babb
1helpful
No external hardrive recognition
It could be that the drive is not formatted/Initialized as yet! Right click on "My Computer" the click on "Manage". Go to(click on) "Disk Management". If the initialize disk wizard comes up automatically then just follow the wizard cause that means your disk needs to be initialized. On the right pane you should see all the disks and their status. It could be that your disk is un allocated. Look for the disk that is full black(black means unallocated), right click on the disk and click on "Create Partition" Follow the steps of the Create Partition Wizard( It will give you the option to format, DO THAT! If when you right on the disk and all that shows is "Initialize", then do that! and go back and create the partition! Hopefully that should do the trick!
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
