Question about Tecnik TKL9260 Front Load Washer
Tecnik tlk 925 washing machine not spinning
Hi
I was doing some washing when teh machine starting making an odd kind of high pitched grinding noise, and stopped spinning. It drains ok but just won't spin. It is built in so is a bit difficult to get out, any ideas before i call the repair man.
its actually a TKL925 not a TKL9260
Cheers
  • 43 Answers
Sounds to me like your carbon brushes have worn down if they wear down too far they will hit the metal casing that explains the grinding noise
Posted on Nov 10, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Bosch Classixx 1400 Express: stopped midway through wash cycle, making a high-pitched beeping noise. Water and clothes are trapped in the machine. I have tried setting it to drain and spin - just makes a...
if there is still water in drum the door wont open try tilting the machine back so the water is not touching the door and wait for a click that normly works
Mar 28, 2011 | Bosch Washing Machines
My washer has started making a high-pitched noise while spinning.
Hi
to chek what is wrong follow the bellow instruction....
Check the motor bearings
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer.
Check for Obstructions
Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket.
Check for Grease Spatter
A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing.
Check the Drum for Irregularities
Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Washing Machines
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine won't spin
Could be worn carbon brushes, or possibly defective shock absorbers
Mar 26, 2017 | Tecnik TKL9290 Front Load Washer / Dryer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
The washing unit makes a high pitched loud noise
Check to see if you have a bra underwire or nail stuck in the spin tub. Look around inside the tub looking for something stuck in one of the holes. Dont use the machine until you find the problem or you cut the tub in half with like a nail or screw and then the machine has to be rebuilt $$$$
You may have other problems, However start here. Let me know if you have other questions
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Tecnik TKL9260 Front Load Washer Logo
266 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
