GE 24 in. GSD3960LSS Stainless Steel Built-in Dishwasher Logo
Posted on Apr 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GSD3600 GE Dishwasher will not finish/start a cycle. The washer filled with water and during the cycle I heard a pop like someone knocked something over in the kitchen. I smelled an electrical burning smell. All the lights and the buttons work on the front panel, but when I try to start I hear an electrical buzz like it is trying to start, but nothing happens and after 3 seconds the electrical buzzing stops and the lights on the panel flash. I removed the dishwasher and found that when I hit the start button a metal rod attached to a spring moves down into a black cyclinder next to the motor. I am assuming this is the dishwasher telling the motor to turn on and the motor is bad so it wont start? Is this correct?
  • 2 more comments
  • greg0828 Apr 17, 2011
    There is a light buzzing noise from the capacitor when the washer has power, however, the loud buzzing noise when it tries to start for 3 seconds seems to come from the white plastic part in the top middle of the picture you provided. It has the metal rod going from the motor into it. I have not had a chance to measure the resistance for the motor yet as I dont have a multi meter at home.
    Anyways it seems like everything in the picture you have provided is not sold separately. In fact it is all sold together and I found for $120 with shipping. If you are confident with the information I provided that it is something that is wrong within the picture and I cant buy the parts individually should I go ahead and order the parts? If it could be something outside the picture I will get you teh resistance reading Monday.
  • greg0828 Apr 19, 2011
    The motor resistance is 9.2 ohms and the buzzing noise is coming from it. I thought it was the plastic piece above the motor in your picture as the sound from the motor was traveling though it. I have the washer face down putting the plastic piece ontop of the motor. My bad. Anyways you said the motor was suppose to be 1 to 2 ohms?
    The capacitor has a DC Voltage of 0.5 and a resistance readingof 5 M ohms. On my Fluke reader the M popped up next to the ohm sign. Both the voltage and resistance changed with time in 1 direction after I disconnect from power in order to read a value. Not suprised.
    The water inlet valve has like 1000 resistance across it.
  • greg0828 Apr 23, 2011
    I found a replacement capacitor with the same specifications as in 10 uF, 60Hz, 10000AFC, designed for running motors, but it didnt really fix the problem. The capacitor I bought is rated for 370CAC/B and the original was 300VAC, but was told it didnt matter as that is just the max rating. The motor turns very slowly for a couple seconds then turns off. I left the power on and noticed the motor getting really hot. I bought a multimeter that can read capacitance and the old capacitor was at 0 and the new one read 10 uF so the capacitor was bad.
  • greg0828 Apr 25, 2011
    Thanks, I went ahead and purchased the assembly. Far cheaper than a service call and it is good to know how to troubleshoot in the future instead of I replaced a bunch of parts and it works now lol. You have some good responses and with in adequete time.
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Apr 16, 2011
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
680939
Points
4145
Hello Greg,
Your diagnosis is pretty good, but the buzzing suggests it may be the capacitor for the pump motor that has failed rather than the pump motor itself. The capacitor phase-shifts the AC current for starting the motor.
The drain pump should run briefly at the start of any wash cycle to clear any residual water from the washer and this appears to be where the failure occurs. The metal rod you can see moving is the actuator/linkage from the solenoid which opens the valve to the sump inlet. This doesn't start the motor and it appears to be working correctly.
You need to test the motor and/or determine where the buzzing noise is coming from.
This is an updated part from GE and may look slightly different to the one fitted in your washer, but all of the components are the same. The solenoid actuator you can see moving when you press start is ringed in blue on the left, the capacitor is the black box on the right, ringed in red and the terminals for the power supply to the motor are ringed in green.
If the buzzing is coming from the black box, you need to replace the capacitor or motor - I'll need to check whether the capacitor can be replaced separately. If you have an ohm-meter, test the motor for resistance/continuity across the two terminals ringed in green. You should get a reading of about 1 to 2 ohms if the motor is good. If the buzzing is coming from elsewhere it may be the solenoid for the water inlet valve.
Please test the motor if you have a meter and try to identify where the buzzing is coming from, then get back to me. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
  • 1 more comment
  • DILLIGAF
    DILLIGAF Apr 17, 2011
    Rreplacing the assembly in the picture should definitely solve the problem, but I'd still advise you to test the motor first just in case. The only parts of the assembly available separately are the solenoid and the linkage/armature, but these are also included with the motor/pump assembly. $120 is a reasonable price for this.
    The white plastic part top-middle where the buzzing appears to be coming from is the impeller for the pump. Can't think why that would be buzzing as there's nothing electrical in there. Although you don't have a meter at the moment, you should be able to see the motor or the driveshaft spinning when you start the washer if the motor is running. The driveshaft is the metal rod that goes into the white plastic housing where the buzzing appears to be coming from.
    Is there any sign of the motor actually starting up or running?
  • DILLIGAF
    DILLIGAF Apr 19, 2011
    OK - It's definitely time to switch out the entire motor/pump/solenoid assembly.
    It's the capacitor that has failed, as I suspected, but it's not available separately. The motor is actually OK. The buzzing is due to the motor being unable to start because there is no phase-shift between the armature (motor) and field (stationary) windings. The AC phase between the armature and field windings has to be 180 degrees out of sync for the motor to start and the capacitor provides the phase-shift to the field winding.
    FYI, voltage and resistance testing of the capacitor is not a valid test and testing whether a capacitor has failed can't be done with a volt/ohm-meter. Capacitance testing is much more complex. It would take an age to explain, but if you're interested
    http://www.angelfire.com/electronic/funw...
  • DILLIGAF
    DILLIGAF Apr 25, 2011
    Hi Greg,
    Not sure if your previous comment was a question or a statement? The capacitor you bought is correctly rated for this motor so if the motor still wont start, you need to replace the whole assembly. The motor windings have likely been damaged by the additional heat generated through failure to spin-up. The elevated resistance readings suggest this is the case.
    Sorry for the delay in replying to you. I've been offline for a few days due to some rather nasty malware. I've had to wipe my PC and re-install everything.
    Please let me know if I can be of further assistance.
    Regards,
    BElectric
    Please note: You will need to click on "View More Comments" in the light-blue bar below this message to see future messages from me. This wont appear until next time I post a message to you.
GE dishwasher gives H2O code but it gets water!?!??!
kindly cehck the water inket valve Sometimes, the valve might not open fully during a cycle, causing water flow issues or it may be clogged
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
I have a GE GSD2230Z00WW dishwasher water will not fill on start no power on the fill valve either. Water will come on quick wash cycle and rinse.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
***If everything checks out ok with the water inlet valve, replace the timer or control board.
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
1helpful
Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    ok.
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
GE Front Load washer problem
replace the water inlet valve it is seeping water through the valve even though the cycle has finished
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
