Question about RCA R52WM24 52" HDTV Projection Television
Rca distorted picture -
I have the same problems reported by others on my tv. I saw you suggested the part 259638 for it.
Is this a part I can replace myself or do I need to go to a repair person? Does it come with instructions for replacement?
I believe your post may have had a link in it but I was not able to see it. - what site did you recommend to purchase the part from?
[email protected]
Try partstore.com
Posted on Mar 27, 2009
I am unable to find this part, no dealer has it and RCA no longer makes it. Any suggestions?
Posted on Aug 31, 2008
SOURCE:
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
I have a RCA Scenium HDLP50W151YX1 that has distorted Color (Bad Picture)
I am parting out my tv it was playing good when I shut it off we got a wall hanger we don't need this tv let me know what part you need I'll sale them cheap 2705898074 call me if you want
Oct 02, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
Picture convergence and double lettering
there is a bad dioded rca part # rca 259638 its in the convergence part of the tv it has to be replaced
Aug 03, 2008 | RCA R52WM24 52" HDTV Projection Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 27F530T Sound, no picture
if no sound u better replace the audio ic and find the resistor of 100k fi not working,replace the cpu.
Jun 08, 2008 | RCA 27F530T 27" TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
87 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
