Question about LG RU52SZ30 52" Television
HOW TO REPLACE LAMP IN REAR PROJECTION TV AND RESET HRS
  • DRBUGS 101 Aug 08, 2008
    IT IS A LG 52SZ8R-TB THANK YOU FOR THE HELP
    CHEERS
    GLENN
Hi for the lamp replacement ,you have to undo lamp cover from right hand side and then slide out thelamp case .to reset the lamp time,you have to press 'mute' on your remote and press 'ok' at the same time on front panel.
Posted on Sep 25, 2008
Magnavox 50 ML8105D/17
Posted on Aug 31, 2008
  • 4,234 Answers
Without knowing the make and model, I can't give you details. However, the replacement lamp will come with detailed instructions for its replacement including diagrams. Also, the owner's manual will provide you with the procedure to zero the lamp hours. If you need more details, please post the make and model numbers.
Thanks,
Dan
Posted on Aug 08, 2008
The tv comes on but no sound or picture
Your rear projection lamp is defective you need to reset the program when your replace the lamp because you already reach the hrs use of the projector. Or the connector on the lamp lose.
Sep 24, 2011 | RCA D52W19 52" Rear Projection Television
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
When cut on times out and cuts self off. some times comes on and the picture is good
The tv projection lamp been inside the tv like 1 1/2 or 2 years already and tv been on used daily like 4 or 5 hrs daily?Yes,the tv projection lamp life are ending.Replace the tv projection lamp.
Mar 18, 2011 | Sony KP-46WT520 46" Rear Projection...
Shuts off by its self
Tv LED light "LAMP" flashes or tv projection lamp been inside the tv like 1 1/2 or 2 years,tv used daily like 4or 5 hrs a day?Yes,the tv projection lamp is dead.Require a new tv projection lamp.
Mar 16, 2011 | Samsung HLN5065W 50" Rear Projection...
Why does my tv keep turning itself off
The tv projection lamp,might require replacing?Tv projection lamp inside this tv like 1 1/2 or 2 years already and tv daily used,like 4 or 5 hrs viewing of the tv?Yes,than projection lamp is the problems and the causes.The tv projection lamp require replacing.
Feb 25, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Lamp rest light
Press and hold the Mute button on the remote and at the same time press the Enter button on the TV until the Reset menu appears. Press Center button on remote to clear hrs. Your done!
May 27, 2009 | LG RU-52SZ51D 52" Rear Projection...
Warning replace lamp
common problem with this tv. About $130 to replace lamp + service ask ahead for that cost. These lamps are available through the internet. Time left is usually 200-0 hrs after warning
Dec 29, 2008 | Sharp 56DR650 56" Rear Projection HDTV
How to reset hours (4000) after replacing lamp
when you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
LG RU52SZ30 52" Television Logo
256 people viewed this question
