Question about GE Adora JBP77SMSS Stainless Steel Kitchen Range
I have the GE Adora range. I turned on the oven and it made a loud noise, I saw a bright light and the inside of the oven is covered with a gray dust. It looks like the element shorted out. Now the buttons on the range don't work, I can't change the clock etc. What all needs to be fixed
SOURCE:
Krazytech
  • 725 Answers
SOURCE: GE Adora Griddle Top replacement
part number for the griddle is WB31K10140
partstore.com has it for $87.95 hope it helps
Posted on Dec 23, 2008
  • 11 Answers
SOURCE: oven problem
Dear Sir, Simply put, the reason why an element can short out the clock/eoc/digital display is because unlike most other electronics, elements on a range work off a higher voltage. 240 volts. that's why the breaker in your basement is a double breaker. the element normally has 120 volts to it at all times, and when you press bake on your clock or turn your oven on, another set of 120 volts goes to the other side of the element, creating that warm red glow on the element and allowing your oven to heat. if the element blows out and shorts to the chassis of the oven, you risk damaging any other electrical componenet. As this may seem not fair, it's better than encasing the element in something, shorting out and causing a huge electrical fire. When the element shorts out and there is no ground for the current to follow, it's just like welding some metal together and very dangerous.
Posted on Jan 20, 2009
SOURCE: I just bought a GE ADORA range and scratched the
I would go to the manufacturer's website:
http://www.myapstore.com/Omega/Dispatcher?REQUEST=STARTSHOPPING&zipcode=40225&couponCode=Promo+Code&username=P9900103&password=anonymous
and type in the 'part number'.
The above link is for their store. I don't have this appliance and i don't know if the definitely replace it. ut I figured you could at least start here.
Hope this helps!!
Posted on Mar 23, 2009
  • 189 Answers
SOURCE: GE JBP90 Electric Range - keypad not working
Hi-  If everything worked when stored, problem could be simple. The keypad is linked to the computer with a ribbon connector. The plug may have gotten corroded a bit in storage. Try this first: Unplug power. Remove back panel to access control. Remove four screws holding control. Unplug and inspect connector. Clean with a toothbrush and compressed air if you have it. Plug connector back in, re-assemble, and see if touchpad works.  Let me know if this info helps.  Have more if needed. - Ed
Posted on Mar 18, 2010
Testimonial: "ejasperse - Thanks for the suggestion. Unfortunately it didn't work. I pulled it apart and tried to clean the connection, but I still have the same problem. Any other suggestions?"
heatman101
  • 43501 Answers
SOURCE: Is there a grill pan
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Jan 16, 2011
Loud noise when cooking
I had an arcing sound coming from above the cardboard panel inside the microwave. When I saw it sparking I took the cover off and saw that these two aluminum looking things had come loose. I removed the cover and did a fair bit of 'fine tuning' to get it working again.
Apr 03, 2014 | KitchenAid KHMS2050SSS Microwave Oven
JGB900 oven won't work. Range top works, broiler works. No glow in oven. Regulator is on.
Your problem is with the oven ignitor. Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Feb 17, 2011 | GE Profile JGB900 Gas Kitchen Range
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
How to convert oven from natural gas to propane on a ge adora gas range
i need the correct part numbers to convert a GE Adora model JGBP87SEL2SS from LP to NG,
Nov 02, 2010 | GE Adora JGBP87SEMSS Stainless Steel...
Top burners light, oven will not gniet
may be a simple glow plug problem, will need more info to determine for sure.
May 09, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
Dec 23, 2008 | GE 30" Self-Cleaning Freestanding Gas...
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Oct 13, 2008 | Frigidaire Kitchen Ranges
GE Adora JBP77SMSS Stainless Steel Kitchen Range Logo
51 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
