With a new charger and new batteries there can only be one other problem assuming all the wiring is connected properly. There is a 7.5 Amp in-line fuse hidden in a fuse holder off the charging harness. This fuse may have blown. I usually check this fuse first since it is usually the culprit and most difficult item to locate under the back cover. In rare cases the ammeter burns open and will cause the unit not to charge. After checking the fuse you can jumper one or both these items to see if it will charge and then purchase new parts. Hope this helps.
Where is charging harness
