I have no connection to the internet.The dsl light is flashing,i have checked all connections and changed the micro-filter.I am connected at the moment via another router.
    Problem Solver:
  • 4 Answers
It's your router. If you got it from your local phone company then contact them and let them know that you need a new router or they can send a tech out who will then check and if need be will put in new values for incoming. You can also check your local electronics store about purchasing your own router for DSL.
Posted on Aug 08, 2008
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
When i connect with the internet and my phone rings, the internet connection is interrupted and I cannot use the phone and internet at the same time. please helps
I'm goign to asume here that you have DSL by your problem. If I am incorrect then please let me know.
With that said, first you need to check that your dsl filters are correctly connected and functioning correctly. If you hear a static or fuzzy sound on the telephone even echo this will be the casue from a bad filter or non-existing filter.
A filter that is bad or missing will cause DSL to drop its connection. The telephone call will cause too much interruption with the dsl signal and causes the modem to drop the connection to reconnect with a more solid connection.
So what you need to do is check your filter by changing it as well as checking this problem that it happens on all phones not just one individual.
Please get back to me if you need more information or this does not help you.
Jan 27, 2011 | 2wire (2701HG-B) Wireless Router
My att 2 wire keeps flashing red on and off for dsl and then the green wireless light goes off and internet goes down. I get a msg that the broad band cannot connect. I have checked and double checked...
Hi
This is Neo . Check the Filters in the phone line if you have installed the filter . if there is no filters before the telephone , install a filter . Whether the phone line are connected properly and check the wall point where the connection from the DSL and telephones . Check the cords and try changing the RJ11 cords . RJ cors the phone thin cords .
NOTE : FILTERS SHOULD BE INSTALLED FOR TELEPHONES BUT NOT FOR 2 WIRE .
Nov 02, 2010 | 2wire 2700HG-B Router (2700HGB)
Assistance with blinking light on my DSL modem
First thing to do is unplug your DSL modem and leave it unplugged for about a minute then plug it back in and see if problem is corrected. If not you should contact your ISP tech support. You could have a bad line from the phone company or bad connection in your house. Also if you have filters installed on your other phones you can have a bad filter that is causing interference and keeping yoiur DSL from working properly. You should go to "Start" > "Run" and type cmd and hit "Enter"
In the command window type ping google.com -t (Enter) This will start a continual ping. If you are getting ping times exceeding 70 - 120 ms that could be a sign your DSL is not functioning properly or if you get packet loss. That is when the ping time doesn't return a time periodically.
Sep 23, 2009 | Westell Wirespeed LiteLine 6100...
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Jul 20, 2009 | Efficient Networks SpeedStream 5667 Modem
Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
Nov 03, 2008 | D-Link DSL-2320B
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
