Question about Rockford Fosgate Audio Players & Recorders
How to install Rockford Fosgate 3sixty.1 to a Toyota factroy head unit?
    President:
  • 624 Answers
You will need a line level adaptor to get an audio input for the amp.
A line level adaptor is a device that lets you tap off of your speaker outputs of the radio and it converts that signal into the proper level for an RCA input signal the amplifier uses.
If you are installing the amp in the trunk of the car you can just tap off the speaker outputs of the rear speakers mounted in the trunk. Keep the speaker outputs connected to the speakers, just run an extra set of wires from them to the line level adaptor. It will not take anything away from the speakers sound because it is not a power drain on them.
After that, you just connect the power wires for the amp as you would normally and you also need to run an extra wire from the radio power antenna wire to the remote turn on of the amp, or you can use a wire directly from the battery and connect it thru a switch you would need to connect somewhere around the dash, so you can turn the amp on and off when you need to. The power antenna wire from the radio is best, so you don't need to turn the amp on and off manually. It is easy to forget about turning it off sometimes and that would run doen your battery if the amp is left on over night even with no signal going thru it.
Then connect your speakers to the amp and thats it.
Then big issue is getting an audio signal to the amp and the turn on signal for the amp.
If you need more help let me know,
Dave
Posted on Aug 08, 2008
SOURCE:
How can I add bluetooth to my 2009 :'( acadia so I can answer phone calls while I'm driving
Hello Robby Clark,
Look up Rockford Fosgate 3Sixty.3
(as I recall about $600 to add hands free Bluetooth).
I have found a couple of opportunities...
by going onto Crutchfield.com...
You put in your vehicle specifics... and what you are trying to accomplish... a lot of AFTER-MARKET radio opportunities present...
In my case MY STOCK RADIO NAVIGATION SYSTEM... touch-screen VIDEO... w/THX (theater sound) was already pretty nice...
rockford fosgate 3sixty Crutchfield Car Stereo Speakers Home
Theater Pro Audio 4k TV
Amazon com rockford fosgate 3sixty 3
May 29, 2016 | Cars & Trucks
Jl audio 1000/1 amp not turning off why?
Have you wired the remote cable to the permanent live on the head unit instead of the switched? Is the anything that could be shorting the feed +V to the remote on terminal?
Has you just installed it or has it been working?
Apr 25, 2012 | Rockford Fosgate Car Audio & Video
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
How can I get rid if whining noise comming from inside of my rockford fosgate 1000bd
wrap a striped wire figure 8 style around the output rva jacks on the back of your head unit
Apr 03, 2010 | Rockford Fosgate Power 1000BD Car Audio...
Where is the aux plug for this radio; Eclipse's optional Rockford Fosgate premium audio system
The Mitsubishi Eclipse with the Rockford Fosgate premium audio system does not actually have an aux plug. When you are scrolling through the sources, one of them listed is an AUX. This implies that there is a headphone jack somewhere in the vehicle where you can plug an iPod into and play it through the system. The port, however, was never actually installed on all pre-2009 eclipses.
The only way to access this feature of the stereo is to obtain an AUX cable from the mitsubishi dealer, which will be a wire harness that connects to the back of the head unit and provides an additional AUX port cable allowing you to plug in your iPod. You can talk to your local mitsubishi dealer about the cable, from what I hear, its rather expensive, and then go to best buy, somewhere similar, to have them install it.
Aug 06, 2009 | Rockford Fosgate Car Audio & Video
How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Dec 03, 2008 | Rockford Fosgate 25 To LIFE Punch 150...
Rockford and fostgate
i dont think different brands ar compatible as such.
Dec 01, 2008 | Rockford Fosgate RFX-8030 CD Changer
Rockford fosgate punch 700s gets very hot
Disconnect the speaker wires from speaker terminals on the amp and turn the amp on (turn the head unit on). Set the volume to zero on the head unit.
Does the amp get hot?
If it does, either the bias is set to high or the amp has other problems. If it does not, you may have the speakers wired to the wrong ohm load.
Nov 03, 2008 | Rockford Fosgate Punch 700S Car Audio...
Rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Aug 16, 2007 | Rockford Fosgate RFX-9200 CD Player
470 people viewed this question
Top Rockford Fosgate Audio Players & Recorders Experts
 Grubhead
Grubhead
JonSnell Electronic
JonSnell Electronic
Are you a Rockford Fosgate Audio Player and Recorder Expert? Answer questions, earn points and help others
