Question about Kenmore 63942 Dryer
Dryer won't run unless we hold the button
We need to hold the button to run the dryer and not sure if it's some kind of sensor problem. there is heat coming out when we hold it down so I'm not sure what the problem is.
  • 550 Answers
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, good for another 10years
Posted on Aug 10, 2008
  • bondo_12345 Dec 21, 2010
    I have this exact same issue but when I held the button on the motor caught on fire I beleive. I just tore it apart because the night I believe it caught on fire there was smoke comeing out the back. When I tore it apart there was black suit on the motor. When I was holding the button the tumbler was turning but soundend like it was pulling alot of amps (overworkin)
Dryer won't heat
Most sensors ( limits) have at least one screw holding them onto the unit.
Jan 21, 2013 | Maytag Atlantis MDG6400AW Gas Dryer
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
Whirlpool electric dryer
Hello there and welcome to Fixya :
This is a fairly common problem with these whirpool dryers.
I will provide you with the 7 most common things to look for
which contribute to the symptom Dryer won't stop are listed below. Check or test each item and watch any available videos. If you are still unable to solve the problem you may need to do additional research and troubleshooting.
Show all parts for model GEW9878LW0 For the symptom you selected, these are the most common parts or causes, ordered by the likelihood of fixing the symptom.
othercausesandconditions.jpg Air Flow Problem The most common problem when a dryer is slow is when the vent is clogged. If the dryer is slow, check the vent from the back of the dryer to the outside of the house. If that is clogged, clear it completely and test the dryer. If the dryer is slow after the vent is cleaned, clean the internal ductwork of the dryer. This will require some disassembly.
blower-wheel-694089-00918612.jpg Blower Wheel
Item # 686172
The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft.
Skill Level Skill Level
Part Replacement Video $23.40 Quantity:
In Stock
heating-element-assembly-3401338--00621237.jpg Heating Element Assembly
Item # 528055
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity.
Part Testing Video $91.05 Quantity:
In Stock
lint-filter-349639--00685658.jpg Lint Filter
Item # 2659
Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
$38.95 Quantity:
In Stock
moisture-sensor-279366-00565298.jpg Moisture Sensor
Item # 469522
Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or coated with fabric softener. Clean the moisture sensor contacts inside the dryer and th
Oct 11, 2012 | Whirlpool GEW9878LW Electric Dryer
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
My Kenmore 80 series dryer won't stay on unless I
You are going to make me guess!
I am guessing you have to hold the start button down.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Jan 05, 2018 | Kenmore Washing Machines
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
You have to hold down the start button, once you let go the dryer stops. When I put something on the button to hold it down theres no heat. Only heat on heat sensor mode.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Apr 21, 2011 | Dryers
I have a Bosch nextt 500 series dryer and after 2 years of use the problem I have is the heat will shut off and the dryer will keep running and I have to press the reset button on the backside of the dryer
Open the front panel, remove heat exchanger and clean. also clean out lint tray. this might help a little. Now lets check if the thermal sensor or heating element needs to be replaced.
Unplug the dryer. remove the panel in the back of the dryer that covers the heating element. ( the inner panel). On top of the heating element you will see a thermal sensor with a small red button on it. Thats the manual reset button. To test if the heating element is working properly you can disconnect the wires from the sensor and clip the connectors together . Plug the dryer back in and start it. pay attention to the heating element. It should begin to glow shortly. if it doesn't then your heating element is bad and needs to be replaced.
Unplug the dryer. Connect the wires back to the thermal sensor. Plug the dryer back in. Before you start the dryer, press the red button on the thermal sensor. Start the dryer. If the heating element doesn't come on and dryer doesn't heat, then you need to replace that sensor.
Feb 01, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
Kenmore 63942 Dryer Logo
181 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
