Question about Lexmark Color Z35 InkJet
Removal of black ink cartridge Lexmark Z35 printer
As I do not have a manual for this printer, I cannot see how the ink cartridge is removed. Can you help me please.
Put your printer "on", then open the central lid, where "lexmark z35" is written. The cartridges appear.
Open the dark green lid (on the right), same color as your new cartridge. Remove the old cartridge and put the new one in, after removing the tap.
Your printer should print a test page. If it doesn't, go to "printers" in the "control panel" (panneau de configuration in french !), right click on your printer name and chose "properties".
Posted on Mar 28, 2009
I just got a new black ink for my Lexmark X6150 printer and when I did the alignment test, it turns out a like dark grey instead of black. The printer also said to remove tape from ink but all the tape has...
You should try cleaning your cartridge nozzles. If you're using Windows, go to Start -> Programs -> Lexmark X6100 Series -> Lexmark Solution Center -> Maintenance tab -> Clean to fix horizontal streaks. The printer will then print a test page.
You can also manually clean the cartridge nozzles. Follow the steps in this article : How to Clean the Print Cartridge Nozzles and Contacts Manually.
Thanks.
Feb 10, 2011 | Lexmark X6150 All-In-One InkJet Printer
How do i install the ink cartridge in my lexmark z35 printer
Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
Wait a moment. The cartridge carrier will automatically disengage.
Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
Carefully pull the tape off the new cartridge.
Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
Close the printer's lid. Print a test page to ensure everything is working properly.
Oct 31, 2010 | Lexmark Computers & Internet
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    REMOVING OLD INK CARTRIDGE
    Click on this link:
    Z600 Series Manual
    Go to page 42. There are detailed instructions for removal and replacement of your cartridges. (With pictures.) :-)
    Thanks for using Fixya.
    Jun 19, 2009 | Lexmark Z640 InkJet Printer
    Lexmark x5470
    Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
    Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
    Lexmark x4850 ink levels won't reset with new cartridge
    Hi...
    Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
    Jan 25, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
    Color cartridge won't print/ black and white is fine
    Hi Franelyn !!
    giving u some steps so that you get anser to ur question that why your color ink cartrideg is not workign
    It might be beacuse of faulty printheads of printer or fauly printheads of cartridge
    To check which one is faulty : take a tissue or cloth ...slightly moistened it with water an dtry to clean nozzles of cartridg and observe that some ink is coming out from cartridge or not , if not shake the cartrideg again clean its nozzles , if still no ink comes out that will ensure that the cartride is bad
    Nov 29, 2007 | Lexmark X1270 All-In-One InkJet Printer
    Colored Ink problem
    Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
    Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
    Nov 19, 2007 | Lexmark Color Z35 InkJet
    Colored Ink problem
    Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    Lexmark Color Z35 InkJet Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
