Question about Amana Refrigerators
Amana AFD2535DES French Door Refrigerator similiar to this one noted Problem: Ice maker makes hollow ice! Why? Solution by: seifrij (31 solutions) Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be... tried to get kick panel loose donna Hoff
The left hand door drags on the refrigerator. Is there an adjustment or do I need to change the lower hinge?
Posted on Aug 22, 2008
My Amana French door bottom refrigerator is making a buzzing noise. The noise is intermittent and seems to be getting worse. The ice maker seems to be work ok. Any suggestions on how I might fix it?
I USED TO HAVE THE SAME PROBLEM. CHECK TO MAKE SURE THE WATER LINE BEHIND THE UNIT IS NOT VIBRATING AGAINST IT, CAUSING THE NOISE. ALSO CHECK THE BOLTS ON THE BACK OF THE UNIT TO MAKE SURE THEY ARE TIGHT. THE HOSE WAS MY PROBLEM AND WHEN I FINALLY FIGURED IT OUT, I WAS SO RELIEVED NOT TO HEAR THAT BUZZING NOISE ANYMORE. AND I THOUGHT IT WAS ACTUALLY INSIDE THE FRIDGE!
Jul 14, 2011 | Amana AFD2535DES French Door Refrigerator
No water to water dispenser or ice maker
Mike I just want to be sure I understand you correctly. Does it sound as if the icemaker is turning? Or the parts in the dispenser door are making the noise? Here is a link to the=> AFD2535DES Service NManual and here is the=> AFD2535DES Technical Information I find going over the manual and discussing what is happening with me your best bet other than paying someone. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
May 30, 2010 | Amana AFD2535DES French Door Refrigerator
ICE MAKER MAKING NOISE BUT NOT MAKING ICE
What sort of noise?. If it's a buzzing noise, it could possibly be the hot gas solenoid is still energised, thus defrosting the ice frame.
Apr 17, 2010 | Amana AFD2535DES French Door Refrigerator
Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be that the timer needs to be adjust.
If the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
To adjust the timer, follow the instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Jul 16, 2008 | Amana AFD2535DES French Door Refrigerator
Is there ice in the maker?
You'll want to pull the icemaker. Start by disconnecting the wires and then remove the screws holding it in. Check the gears that make the ice maker ams turn. Make sure all the teeth are still on the gears and that there is nothing obstructing them from moving.
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
81 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
