Hp 1530 green light turn on and off - Computers & Internet
  • laurentjr Aug 08, 2008
    I should a mention this is a lcd monitor from hp model 1530, the green light turn on for about 4 seconds and then turn off for a second, it must be a power supply problem, i will resolder the power suplly part. thnaks for the help
    Problem Solver:
  • 4 Answers
Check the power supply box while plugging in the cord to the computer. If the fan does not spin up in the power supply, you probably have a bad power supply.
There should also be a little bulb on the motherboard, if it is not on, then you are not getting any power to the motherboard. Which again is pointing to a bad power supply.
You can also go to HP.COM and search there for the answer. Hopes this helps and if it doesn't then let me know,ok.
Posted on Aug 08, 2008
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
1530 screen is green with no way to access stitch panel.
it's possible that the motherboard is going out,, but it would be a
good idea to have the machine checked.
Feb 12, 2013 | Sewing Machines
Is not working more
Switch the printer off.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
Hp 1530 has no sound
you need a sound driver for it go to and find your sound hardware and download the driver.....they are all free!
May 16, 2012 | HP Computers & Internet
Security code of nokia 1530
saya lupa kode kunci hp nokia 1530 saya.
Nov 07, 2011 | Nokia Cell Phones
Powered down my cpu (hp pavilion 1530 ) and about 5 hours later it would not power up. Hit he power button and nothing, no fans, no blue light, no cdrom bliking, but the green led is lit on the P/S.
Open your tower:
Remove first the video card if you are using a Add in video card. Of course connect your monitor to the built-in video card
Try now
Next remove ram and reseat them back ( if you have more than one stick, try reseating only one)
Try now again
Disconnect CD-rom, Hard Drive
Try now
Last but not least try a different Power supply
Good Luck
Apr 29, 2011 | Computers & Internet
OFFICEJET 5610 COLOR AIO Printer: I have an hp 1530 that wont print in color after w...
Open HP solution center.
click on settings >>> Printer settings >>> click on Color tab..
select print in color. Click on OK.
Now try to print
May 07, 2010 | HP Officejet 5610 Color All-in-One Printer
Cursor jumping around when typing on a Dell 1530
It is most likely the touch pad...a way you can tell is if you have a USB mouse, turn off the touch pad and use the USB mouse...go to type and see if it still jumps around.
Sep 16, 2009 | Dell XPS M1530 Laptop
Copystar 1530 copier Power Source PCB defective
Hello sir; You have to make sure this board got problem (reminder; did you check the fuse) after you bought the board that's non refundable, if you still need that call me at 9735336778 Everett Lin.
Jun 03, 2009 | Copystar CS-1530 Copier
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
