Question about Kenwood RCR0907 Remote Control
Light has stopped working
The blue light on the display has stopped working, how do i find it inside the remote and is there a fix??
  • RAWMRN4 Oct 11, 2008
    THE BACKLIGHT HAS STOPPED WORKING IN THE REMOTE. HOW DO I FIX IT?
  • Paul HInman
    Paul HInman Oct 16, 2013
    Did you ever fix this? I just got this remote on ebay and it has no backlight either.
Honda CRV Keyless Entry stopped working. Pushing any button on either remote does nothing. They both just stopped working at the same time out of the blue. All doors function properly from inside
Check the batteries in the remotes. It might just be a massive coincidence and the 2 stopped working at the same time. Failing that I would guess the reciever is the problem
Dec 04, 2012 | BMW X5 Series Cars & Trucks
Hampton Bay 5745a ceiling fan, no blue wire.
The blue wire is running into the built in receiver inside the fan housing. You will not be able to install another receiver to the fan and have control of the lights. You will be able to control the fan though.
Aug 02, 2012 | Dryers
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
My unit was working properly, when it fell "gently" from a chair-side table onto a thick carpeting and rolled over about three times. Nothing dramatic. But from that time the display screen has...
Hello
Just open the remote control without damaging its case. In some remote controls, there may ba onw or two fixing scrrews inside the battery compartment. Look ofr it if it is there, if not you can open it with any sharp instrument like a knife or so, by put it in betweedn the **** between the to case parts at its side. Hold it upside down and open. There will be a strip wire that connects the LCD display and the main board of the remote control. In some remote controls this strip wire will be a replaceable one. In some others it will be pressed either side to board and display. If the second said type is yours, it can't be repaired. If it of the first said type, the wire can be replacable, and can be bought from electronic spare part shops. Its conductors are of carbob track type, not made up of metal wire. During the fall, there is a chance to make these conductors to break. There is only back light LED is working now. Sometimes the remote may be also working, but you can't see its doings on diplay. Check it. As you said that the battery inside it is deformed durring the fall, as from that I understands that the hit got by the remote control during the fall was strong. Anyway open it and check these. OK
Jan 23, 2011 | Logitech Harmony 890 LCD Remote Control
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Harmony 659
In the screen display only appear the next commentary "upgrade firware succsesfully", but the remote control doesn't make another activity
Aug 03, 2007 | Logitech Harmony 659 LCD Remote Control
Kenwood RCR0907 Remote Control Logo
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
