Question about Sony KDF-E42A10 42 in. LCD Television
Yellow circle we heard a loud pop, now we have a hazy yellow circle in the center of the picture, I replaced the bulb.
  • rdkng Feb 05, 2009
    i too have this yellow hue just larger than a basket ball. help
    Scholar:
  • 52 Answers
There are a couple of things that this could be caused from.. Its hard to say without actually looking at the set, but they are as follows.
The lamp is what you heard pop, they are under extreem pressure when on, and when they get to the end of there life, they will expolde if not changed in time.
The circle can be caused by 3 things.
1 : when the lamp exploded, it knocked the internal mirrors and lenses and or burned them due to high heat and brightness of the explosion.
2 : The polarizing filters that are infront of the lcd could have also gotton burned.
3 : The lcds could have also been burned.
If the haze happened right after the pop, I would expect that you bumped one of the lense or mirrors in the optics out of whack or even cracked the glass. If the haze has been present prior to the pop, then your lcds or filters are shot.
Posted on Aug 09, 2008
Have a mitsubishi XL6600u projector .....screen is yellow and have replaced bulb still yellow
Could be one of two problems. How old is the machine? If one of your LCD filters inside the machine has burned up it will show yellow. Common on SL4U. It starts with a yellow circle. If not that then most likely a bad VGA cable. If you have it hooked up that way.
Dec 06, 2012 | Mitsubishi XL6600U New
Epson projector has yellow circle in middle of image, as if the lamp has caused something (lens maybe) to become yellow.
Probably had too high wattage bulb and basically, it burned the lens cover. Remove the old lens and "project" to see if the yellow circle is projected. Iif so, purchase a new lens cover.
Sep 02, 2010 | Office Equipment & Supplies
We heard a loud pop and the tv turned off and
That sounds like the lamp bulb blew and you will need to replace it. You can find ads on this web site that sell DLP bulbs at a decent price and you can install it yourself, or you can call 1-800-samsung to find the nearest service center.
Jul 16, 2010 | Samsung HCM4215W 42" Rear Projection...
No picture. no sound
Bulb may have popped. Cheapest fix, unless your an electrician it the only thing to really try before replacing set.
May 31, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I replaced the bulb 4 months ago and am getting about a 15 inch yellow hue circle in the center of my screen, did I get a bad bulb or what can I do?
no its not the lamp im sorry to tell you but you have a bad light engine if its a sony and less than 5 years old sony will replace it for free
Feb 03, 2010 | Televison & Video
Tv picture does not come on
my first question is have you checked the bulb. the loud pop sound like the bulb blew and the rattling sounds like the lamos trying to fire. remove the bulb cover and unscrew the bulb
Mar 18, 2009 | RCA Scenium M50WH187 50" HDTV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony KDF-E42A10 42 in. LCD Television Logo
144 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
