SOURCE: oven and keypad will not work.
longtallez The first thing I would recommend you to do is to reset the power. Locate the circuit breaker for the range and turn it off, wait a few minutes and turn it back on. It works the same way like you reboot you PC when it gets stocked. Let me know if it would not help and we will go further. Gendos...post back
SOURCE: My oven when I go to turn it on fashes f1
We frequently see F1 errors due to a fault in the oven controller (electronic clock). On some of the Frigidaire models it can also be caused by a faulty temperature sensor probe. If it turns out to be the control board, your may want to check out our website. We repair oven control boards.
website: www.fixyourboard.com
SOURCE: need owners manual for tappan gas range model #tgf351es
I would have suggested to go back to the Outlet where you brought and ask them to order the manual for you,
They should also be able to email you the suppliers link,
Hope this helps,MISTERDJ
Hi Gail Muster - Unfortunately from my research for this particular model it is not possible to open the cook-top without a certified service tech.
