Question about Frigidaire GLTF2940ES Front Load Washer
Buzzing sound then "ddo" flashes on panel
Came home from vacation and daughter told me washer was broken. Can't find a specific model number on the machine or the paperwork. Front Loading "energy star" notation on the soap dispenser drawer. Abou 5-6 years old. Clothes are in, soap is in dispenser, press start (on any cycle) and you hear something start for about 5-10 sec. and then the lighted panel flashes "ddo". Nothing in the owner's manual about error codes. Checked water hoses to make sure they hadn't been turned off... Looking on internet and can't find a "error code listing" to even get an idea of what it is trying to communicate.
thanks, in advance.
ctf
  • 1 more comment
  • randyalinton Oct 02, 2008
  • chris daley Oct 09, 2008
    The buzzing sound is the door look being held in, but my machine also has 'ddo' in the display
  • skyblueshome Oct 17, 2008
    have same error code. according to repair guy ddo is code for dispensor door openm he said part was $250 and not on truck. did not order part and do not think dispensor door is problem, if it is than i no longer want this brand. looking at buying a bosch. would still like to fix the machine, but 250 + 70 for a service fee is steep for a guess at a fix.
    Sergeant:
  • 276 Answers
Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps
Posted on Nov 18, 2008
SOURCE:
Gallery Washer will not drain..
Good Afternoon Friend,
I understand that your Frigidaire Gallery washer will not drain. I see that you have a buzzing sound on the selector but there is no reaction from the pump. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power keep and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Washing Machines
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
2004 f150 transmission fault light
Sounds like the transmission got overheated. I would not worry if shutting it off and restarting got rid of the fault.
Enjoy your vacation.
Jul 06, 2010 | 2004 Ford F150
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
We went on vacation and turned off the water.
Turn on the water, unplug machine and plug it back in.
Sep 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
136 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
