Question about HP Photosmart C6180 All-In-One InkJet Printer
Error - Scanner could not be initiliazed
Here is the full error message:
“Sorry, scanner could not be initialized.
(An error has occurred communicating with the scanner.)”
I’m on a Mac, OSX 10.5.4.
I have the latest drivers of the HP Scan Pro software installed (7.4.5).
The device is connected wirelessly and I can print to it without a problem.
The scanner has worked without a problem since the installation.
I have rebooted the scanner (switch off and back on).
I have restarted the scanner software several times.
That’s all I can think of for now. Any ideas.
Thanks!
Oliver Weedon
  • 4 more comments
  • sandraweiner Aug 11, 2008
    I'm having exactly the same problem since a power outage last week - this is new for me - help please
    BTW I'm really unhappy with the level of support HP has given us Mac users!
  • joanofarc30 Aug 14, 2008
    Same thing here, guys. I’m leaving for college in less than a week and I’m not good with technology, so I need to fix this problem ASAP.
    I’ve tried turning it off and on several times, made sure all the cables were connected, did the whole list, and nothing yet.
  • Anonymous Aug 18, 2008
    I too have the same problem. All good until I upgraded to Leopard... Tried reinstalling the software and setting up the printer again with no success..
  • B Uncie Sep 03, 2008
    Same thing here. No solution yet. Though scanning via my webpage works fine.
  • DrewFromNY Oct 27, 2008
    Same as the other folks here. Not sure why this is happening. I will try the solution of dragging apps to the trash and re-downloading from HP. However, I will make sure they are readily available from HP before doing so.
  • Anonymous May 21, 2009
    I have the same problem. I tried reinstalling the HP software and that fixes it, but only for a while. After a few days the problem returns.
I have a MacBook Pro - a year and a half old - and recently upgraded to Leopard, which caused all sorts of problems with my HP 8160 photosmart (which worked pretty well before that).  I downloaded the necessary drivers/softward from HP for Leopard and it worked okay - but than I also started getting the "scanner cannot be initialized" messages (doing scan all wireless).  Anyway, all I did was go to applications, drag the HP softward to the trash and then went back to the HP site and downloaded the software and drivers again, and ran through the simple installation process again and now my scanner works again. Don't know why - but saw the suggestion on another site and it worked for me.  Here is the link to the HP site for software/drivers - select your operating system and it will direct you to the right page.
Posted on Sep 09, 2008
I use windows Vista and am having the same problem. Scanning from the devices webpage works but not from the provided HP software. I also am very unhappy with support from HP.
Posted on Sep 04, 2008
Hplaserjet3005 52.00 error what could be the problem ?
52.00 ERROR A scanner motor error has occurred. Scanner motor rotation is verified at the initialization of a print job.
1. Verify that the scanner motor connector
and the ribbon cable from the ECU are
firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector
is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in
connector J403 on the ECU is fully seated. You must remove the ECU in order to verify this connection.
4. If the message persists, replace the laser/scanner assembly.
Sep 09, 2015 | Office Equipment & Supplies
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
My HP LaserJet P3005n, is not working properly whenever I want to print it initializes and then show Error 52 message.
52.00 ERROR
1. Verify that the scanner motor connector and the ribbon cable from the ECU are firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in connector J403 on the ECU is fully seated.You must remove the ECU in order to verify this connection.
Jul 26, 2011 | HP LaserJet P3005 Printer
My scanner fails to scan documents. It either generates a "warming-up" message OR "sorry, scanner could not be initialized. (Scanner parameter error.)" message.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Nov 20, 2009 | HP PSC 950 All-In-One InkJet Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Apr 24, 2009 | Fujitsu fi-4120C Path-Through Scanner
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Hp scanjet 6200c scanner recognised only as printer by pc
Download this program that will help you solve the problem.
Click here
May 27, 2008 | HP ScanJet 6200C Flatbed Scanner
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,488 people viewed this question
Seeker5211
Seeker5211
