Question about Intel DG31PR Motherboard
Intel DG31PR not supporting 2 dimm each of 1gb
On intel mb dg31pr when i run memtest86, ver 2.01. following is the obervations a/when i use single memory it works 667/1gb b/ when i use 2 memory of 667/1gb it fails. checked memory on other systems it works find. any advice
  • 1 more comment
  • Anonymous Nov 17, 2008
    when ever i try to run duel channel i have problems i have corsair ram never going to buy an intel board again
  • ridwanrafi Dec 18, 2008
    i have tried to use two 1GB/800MHz RAM in 2 slots and got a lot oferrors using memtest. How can i know SPD information about my RAMs?
  • asrafgen
    asrafgen Dec 15, 2012
    same problem here(it fails when trying with 2 (1GB/800MHz each) sticks in 2 slots), is there any way to solve it??
    President:
  • 2,351 Answers
Memory for Intel motherboards require the memory to be compatible with, Serial Presence Detect (SPD). Its suggested when upgrading memory for Intel boards or increasing memory to do you're search for the total memory you wish & include the Intel mother board model. Example: http://www.google.com/search?hl=en&q=Memory+for+Intel+DG31PR&btnG=Google+Search
This first link shows what brands works with the DG31PR MB.
Intel Tested Memory for DG31PR MB link:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/cs-027918.htm
You're Intel board is well within the Intel warranty. If you find this information not helpful please call Intel tech support. It is possible you're board needs higher attention. Please check & install the latest bios. Intel's link for bios, manual & drivers link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If you are not using WinXP click this link & pick you're current operating system.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Mike
Posted on Aug 08, 2008
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
139
Posted on Mar 13, 2009
Dg31pr sound drivers required
Posted on Nov 05, 2008
SOURCE:
Will Intel DG31PR supports SATA-2 or SATA-3 format internal drives?
The Intel DG31PR motherboard uses an Intel G31 motherboard chipset;
A) Intel 82G31 - Northbridge chip
B) Intel 82801GB (ICH7) - Southbridge chip
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Scroll down to the subheading - G31 in the left column.
The Southbridge chip controls the SATA bus.
The SATA bus uses SATA technology, that operates UP TO 3Gbps.
3 Gigabits per second.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The SATA 3.0 technology operates at 6Gbps.
6 Gigabits per second.
SATA revisions were made to be both Backward Compatible, and Forward Compatible.
However it depends on the manufacturer of the harddrive, as to how to switch it,
http://en.wikipedia.org/wiki/SATA#SATA_1.5_Gbit.2Fs_and_SATA_3_Gbit.2Fs
The answer is yes.
You will not get the full capability of the SATA 3.0 technology, however.
The harddrive will be operating at the SATA 1.5 technology.
Regards,
joecoolvette
[ Here is the Technical Product Specifications for the Intel DG31PR motherboard,
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/CS-029381.htm
Click on in blue -
Intel Desktop Board DG31PR Technical Product Specification [PDF]
Page 10 - Peripheral Interfaces
- Four Serial ATA (3Gbps) interfaces -
Aug 01, 2012 | Intel DG31PR Motherboard
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
Non-ECC DIMMs
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
Mac os x is not run imy pc
to install mac os is simple in dg31pr motherboard but if it does not support to u mean. u have to change in bios some setting it is change hardisk mode from ide to AHCI
Apr 14, 2009 | Intel DG31PR Motherboard
DG31PR Won't Boot
you ight have a BAD CPU, try checking it out on another pc or friends pc.
Jan 08, 2009 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Problem
Memory is key element on all motherboards and hard to believe they are all selective of memory . You have the wrong memory for that motherboard . Sorry . Here is list you can select for the motherboard ( only ones that will work with it )
http://www.intel.com/technology/memory/ddr/valid/DDR2_667_dimm_results.htm
Anything other than what is listed will not work with your motherboard .
Aug 04, 2008 | Intel DG31PR Motherboard
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
453 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
