Question about HP Compaq Presario v3000z Notebook
Mic Probs. I have AMD v3000 pressario notebook,when i inserted mic it does not work nor record any sound. Any solution is highly welcome.
  • 1ITguy Aug 09, 2008
    Hi sivareddy040
    I Highly appreciated your kind response and solution,I will try an will let u know the result.
    Hi, sivareddy040,
    Tried but didn't work,the main problems is Playback option has been disable.
    Any idea?thanks for your info.
Its windows XP.
Posted on Aug 09, 2008
    Scholar:
  • 53 Answers
We need to few more details to fix this issue. Like the OS installed in the notebook and if you are able to hear normal audio from the notebook speakers.
If you are not able hear the normal audio from the notebook speakers, then the issue could be with the Audio driver.
If that is the case, then you can try reinstalling the Audio driver, as it is same driver for both Audio and Mic.
If you are able to hear the sound from the notebook and if only Mic is not working, then you can perform the steps given in the below URL:
For XP:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=bph07158&dlc=en&lc=en&jumpid=reg_R1002_USEN
If the OS is Vista:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00820226&dlc=en&lc=en&jumpid=reg_R1002_USEN
Posted on Aug 08, 2008
  • siva reddy
    siva reddy Aug 09, 2008
    Please let me know the OS installed in the notebook. I mean is it XP or Vista?
    Also let me know if you have tried reinstalling the Audio driver.
Dual microphone issue
drewad125
Technically you can not do this. Most sound cards only support one recording device at a time, especially notebooks. With notebooks usually when you plug in a device it will over ride the build in one.
Now some sound cards give you the option in turn all recording source at the same time so if you laptop would support both mics then you could use this option. The down side is you will be recording from ALL source so you will not want any other sounds going on that you do want in you recording. The steps below will help you check this.
***Note step 4 may not say Analog Mix but if it says mix then most likely you have the option to select all your recording sources.***
1. Click START / PROGRAMS / ACCESSORIES / ENTERTAINMENT / VOLUME CONTROL.
2. Click OPTIONS / PROPERTIES.
3. Select RECORDING beneath ADJUST VOLUME FOR.
4. Insert a check to the left of ANALOG MIX.
5. Click OK.
6. Insert an X beneath ANALOG MIX.
Everything being output via the speakers is now the recording source.
Another option is get a notebook card from Creative Labs as they make sound card. Now if you are doing highend recording you might also look at their highend EMU products as well. I included the links to both there sites.
http://us.store.creative.com/Sound-Blaster-XFi-Notebook/M/B001BS3A3E.htm
http://us.store.creative.com/category/25660134781/1/EMUCreative-Professional.htm
Let me know if you have any questions
Issken
Jan 12, 2010 | HP Pavilion dv4000 Notebook
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
MIC IS NOT WORKING
I had the same problems with mic in windows XP, i installed Vista and it works, if you have any solution for XP , plz let me know.
thanks
Oct 28, 2008 | HP Compaq Presario v3000z Notebook
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Buzzing/humming sound when mic is inserted while on AC power
if its not usb mic you will have the humming
if it is a usb mic the port that you connected to needs a mic to be further away from comp your picking up a static charge from comp to mic
May 26, 2008 | IBM ThinkPad T30 2366 Notebook
Nx7010 mic problem
Did you check the sound settings for the mike?
May 08, 2008 | HP Compaq nx7010 Notebook
Help me with the sound and mic. issue, i am using compaq persio v3000 ...please
I had the same problem with a compaq presario f700 with windows vista this solved my problem hope it helps you.
You need to download a codec called truespeech or tssoft32 link below hope this helps you.
Good luck
http://www.vistax64.com/sound-audio/125595-dsp-group-truespeech-audio-codec.html
Apr 07, 2008 | Computers & Internet
HP Compaq Presario v3000z Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
