Question about Sony Playstation 3 (PS3) Console
Red Flashing lIght PS3
I am having a problem where my PS3 will load up disks or anything on my HDD for a certain point then suddenly cut out and beep and give me a flashing red light. Is there any solution to this. I have already tried cooling it down and so on.
  • Anonymous Dec 28, 2008
    fed light flashing
Turn it on and off 7 times then take out the mains for approx 1 and a half hours then turn on and yellow light will go. repeat process several times and it still won't work BUY A NEW ONE!!!!!!!!!!!!!!!
Posted on Sep 01, 2008
My ps 3 was working fine and all of a sudden it went off. I tried to turn it back on and can on for a sec and then went off again. The light started flashing red.
Dear Friend,
The red flashing light might indicate and error with your PS3 console just follow this step to reset your console. This might help,
Press down the power button, you will hear one beep, keep pressing then, the second beep will sound twice. From there it will prompt you to the reset screen.
Good Luck!!
Nov 08, 2011 | Sony Playstation 3 (PS3) Console
PS3 wont work, red flashing light
If it flashes yellow to you have the Yellow light of death. google it. otherwise its just overheated
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
PS3 red light and shutdown after 3 beeps
sounds like the impact killed the hdd, the disk is damaged and it tries to load out of the boot sector but can't, needs a new drive.
Dec 18, 2009 | Sony Playstation 3 (PS3) Console
The red power switch keeps flashing,, no picetc
The Red light is due to the HDD (hard drive).
There is one of 2 problems:
1. The connection is loose or
2. The HDD is just bad.
This was an issue that has been discussed over in the Playstation forums and it seems that re-seating
(removing & reinstalling) the HDD has solved the problem for many but some people have just
received bad hard drives period.
If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace
your HDD.
http://www.ps3guide.info/fix-common-problems/ps3-3-beep-blinking-red-light-fix
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Downloaded update, next day I got the blinking red light
Mate if you turn your PS3 off when the hard drive is still operating or the power shuts of while playing a game and the PS3 is collecting or writing data to your hard drive, it will most definitely corrupt or even destroy your hard drive it is very common in PC's to.
Hint:
1. Do not shut down your PS3 while it is saving a game or collecting info from the hard drive. Rather quit the game then press your off key with one quick touch and let go of it, it will shut down when it is ready or hold down on the remote's PS button and select switch off system on screen.
2. If you live in a area where the power shuts off for no reason please please get your self a computer UPS(UN-INTERRUPTED POWER SUPPLY).
3. If you replace the hard drive make sure you buy a good quality hard drive like a Western Digital or Seagate.
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Only Green Lights PS3 dont turn on
Usually the "red light of death" on the PS3 as it is called by some people is due to hard drive (HDD) connection errors. Here are a few things you can try to do to fix it and get your console working again as intended, just check out this short video I made (it's less than 4 minutes and contains useful pictures etc)
For more information and advice on how to fix your console, if that does not do the trick for repairing your system, check out my PS3 red flashing lights repair blog.
Hopefully you get your PS3 working again ASAP!
Regards,
James Philipson
Jul 13, 2009 | DreamGear Lava Glow Wireless Controller ...
THE HARD DISK'S FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED
hold in the power button until you hear 2 beeps. might not work the first time. if no 2 beeps repeat power button again or until 2 beeps. go to restore hard disc and click on it. you will lose anything saved on the hard disc but fixes it 75% of the time. did it myself this morning.
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Red light blinking on PS3
If your having this problem I know how to fix it but only for about 30-45 seconds.
Okay this is what you do.
1.If your ps3 is turned on press the red button , it should turn green then yellow ,beep and blink red.
now do this 3 times without turning it off.
2.Turn your ps3 off.
3.Turn it on while holding the eject button.
4.Now your ps3 should stay on ,(like I said for about 30-45 seconds).Also the fan should be on.But then after a while it turns back off.And that's as far as I got.
(It really works if you do it right)
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
