Question about Fuji FinePix 2600 Zoom Digital Camera
Need a new door for the battery compartment - Fuji FinePix 2600 Zoom Digital Camera
  • 2 more comments
  • aaremade Oct 12, 2008
    I need a new battery compartment door. Thanks!
  • Anonymous Dec 08, 2008
    I have the same problem. need battey door for DSC-w1. How can I get hold of one please?
  • veegeevee Feb 09, 2009
    I need a battery door for the fujifilm 2600zoom camera. Please advise where I can find one.
  • soul333 May 11, 2010
    do u have the battery door for the finepix 2600 digital camera
    Problem Solver:
  • 38 Answers
Pl. give us the model no we have DSC-W1 Battery Door in stock.
Regards,
Sharmila.
Posted on Aug 09, 2008
Tip
BATTERY INSTALLATION FOR CLOCK : OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE...
FOR CLOCK
OPEN THE BATTERY COMPARTMENT DOOR. DRIVE THE SCREW
OUT AND INSERT 1 NEW UM4 1.5V BATTERY INTO THE
COMPARTMENT FOLLOWING THE POLARITIES AS INDICATED.
DRIVE BACK THE SCREW TO LOCK THE BATTERY
COMPARTMENT.
FOR RADIO:
INSERT 4 NEW “SIZE D” 1.5V BATTERIES (FOR RADIO) FOLLOWING THE POLARITIES AS INDICATED.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
Tried my new Ikelite AF35 strobe for the first time today and had the disposable everready batteries (new) in for about 45 minutes. After taking some practice shots with the Nikon L22 camera in the new...
Sounds like an O-Ring problem, you need to use a bit of silicon when closing and O-Ring should be removed and cleaned after every dive. If the flash isn't working, you will have to send it in for service. Here is the address;
Ikelite
50 W 33rd St.
Indianapolis, IN 46208
317-923-4523
Oct 17, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
I cannot find a way to open the compartment to change battery in mouse. Have pressed button and pushed and pulled - nothing
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Mar 28, 2010 | Logitech Cordless Mouse
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Battery compartment door
Only by examining the camera your self will you find out If you managed to purchase a part- perhaps an installation diagram is available from the same source.
Jul 31, 2007 | Kodak EasyShare DX4530 Digital Camera
Fuji FinePix 2600 Zoom Digital Camera Logo
107 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
