Question about Sakar Cameras
When i put an sd card into my camera it don't work take it out and put it into another camera it says error with card format it put it back in my camera still same problem take it out other camera says same thing again. they can use away with the card when its formated no problems with them
    Problem Solver:
  • 10 Answers
I have had something like this before.. you might just have to reformat the card in a computer to FAT if same problem happens then format it to FAT32 "this deletes everything from the card"
if you don't no how to do this please ask me
thank you =]
Posted on Aug 08, 2008
3 Suggested Answers
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Posted on Apr 15, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Posted on Oct 25, 2009
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 | Cameras
I can't see and take picture on my DSC-W330 digital camera, it displays an error message "error formatting menory card " and error code c:13:01 how can i resolve this problem.
First make sure you transferred all important pictures from your SD card to your computer.
Then format the SD card "using your camera". Don't format it using your computer.
Thanks for using Fixya!
May 31, 2011 | Sony CyberShot DSCW320 Digital Camera
When trying to playback photos from SD Card, the message "cannot playback image" is displayed. Happens when using more than one SD card, which rules out that it is the SC card that isn't working.
which rules out that it is the SC card that isn\'t working Not necessarily, switching SD memory card from one camera to another without formatting isn't going to happen. If the SD card was new and not formatted in the camera that it's going to be used in then there could be a lot of different errors occurring. Also if pictures were downloaded from the memory card to the computer and the card not formatted this will cause a problem as well. If you have been deleting the pictures files then again this could be a problem the card needs to be formatted. Another IF is if you downloaded pictures from the computer to the SD card and then put it back in the camera without formatting then it's not going to acknowledge the card. If you formatted the SD card in the computer then it's not going to work or work properly in the camera. Picture files can go from the camera to the computer but not back again because the computer operating system and software is not compatible with the camera firmware. It all comes back to format the memory card in the camera you are using it in before taking pictures.
Feb 08, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
My i40 seems to be to be zapping the sd card, I let the camera take a few pictures and then when I put the sd card in my card reader it says card error.
Are you formatting cards on PC? Don't! Let camera format(automatic).Also delete pics using camera and not thru PC or card reader...problem may be card reader.
Nov 28, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
Jun 29, 2010 | Polaroid DVF130 Camcorder
I bought a new sd card and when i put the card in the camera it has an error. my old sd cards still work in the camera. i have bought four different sd cards and tried them in the camera(still getting an...
try to format them into your pc...maybe they are still raw and that why they do not work ...also ..read the manual and see what is the max value supported.. be sure they are formatted .in FAT ..system ..
Jul 15, 2009 | Vivitar ViviCam 3750 Digital Camera
SD Card Error
The NV10 works with MMC and SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
May 02, 2009 | Samsung NV10 Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Cameras Logo
172 people viewed this question
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Tony
Are you a Sakar Camera Expert? Answer questions, earn points and help others
