The colors on this screen are really bad - Computers & Internet
Could be lots of things , cold solder, bent pin on the connecter, or bad color ajustment, bad vga cable.
Posted on Aug 08, 2008
SOURCE:
Hi there, now my hp compaq nc 8000 has one pink line on the screen. But when I try to change my desktop background into black color it disappear but it is not helping at all. when i put the other color in...
the screen is bad, use and external monitor on the rear VGA jack. the line may be gone there, proving bad internal screen.
twist the local screen frame gentle,see line go away or gain more?
yes, bad screens.
this lap top is 12 years old,
use external for the remainder of its life? or upgrade.?
most of these, the back lamps burn out, CCFL lamp tubes.
yours working after 12 years at all is a miracle. really.
most CCFL turn dim, yellow, blink or dead long before now...
I say bad screen but tiny possible loose cable iniside
if others messed around with that cable before, (unsecured)
Jan 08, 2018 | HP Compaq nc8000 Notebook
On half the screen the colors are faded. when a video is watched on the faded half the colors are really bad
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 26, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
I cannot adjust the color.the color is really bad
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 60PP9363 60" Rear Projection...
Colors out of focus- like a really bad 3-d movie
the convergence issue can be usually repaired by replaceing both of the STK392-110 Convergence amps and the six 1.2 ohm 2 watt resistors. You can get replacement parts at the following link with instructions on how to replace the ICs.
http://servicemanuals.vstore.ca/
May 21, 2009 | Toshiba 61H70 61" Rear Projection...
Want help
my screen has really bad color I have tried adusting all the different color contols and nothing makes any difference. there is red streaks through the log on screen and the dark pictures all have red specks through them i called support she wasnt helpful i really think it is in the video card reader but that is way beyond me and my knowledge HELP
Jan 14, 2009 | Acer LXA3706003 Notebook
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Wierd Screen
Autoexec.bat and config.sys help and instructions CLS, MS-DOS command to clear screen. ... line is a driver for DOS to allow you to have different colors / sizes and special characters at the DOS prompt.
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... As the video resolution and color depth increases, so do the required .
Good Luck, Please dont for get to Vote/Thank You.
Dec 13, 2007 | Acer Aspire 3610 Notebook
52 rca concave pic and bad colors
concave and colors off indicate the convergence cuircit is bad. which can be one of three boards. sorry
Dec 08, 2007 | RCA HD52W56 52" Rear Projection HDTV
Computers & Internet Logo
Ekse
Marvin
Marvin
