Question about Brother HL 5250DN Laser Printer
Printer ink faint or not at all
The brother printer has no lights on we have changed the toner and still nothing it either prints very faintly or a blank page? please can you advise?
Regards jane
    New Friend:
  • 114 Answers
The problem comming from leaser unit.
Posted on Feb 01, 2009
Faint printing
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Mar 24, 2014 | Brother MFC-7440N Multifunction Network...
When I print with my brother hl-2070n...the print out is very very faint. i have changed the toner and drum...any suggestions?
if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
Mar 12, 2013 | Brother HL-2070N Laser Printer
My printer shows ayellow light - toner save-and prints faint
You have change the toner save mode first, in the printing window you have a properties options in that you change the mode of printing, if you turn off the toner saver mode in the properties option you can print the documents in normal, dark printing formats. Thank you.
Oct 30, 2009 | Nikon COOLPRINT Thermal Printer
Brother 4070CDW Shadowing Problem
Check your toner if they are properly installed.
Check your drum if they are properly installed.
Clearn your toner and drum.
Print a test page.
If nothing happens please replace your printer drum
Sep 19, 2009 | Brother HL-4070CDW Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
I have a brother mfc 3240C. I have changed the
Apr 23, 2009 | Brother Office Equipment & Supplies
Printing too lightly
Is the paper hot when you take it off the printer? The reason I am asking is, there is a part called a fuser, its the last process in the printing cycle. The fuser gets to almost 300 degrees to melt the toner onto the paper. If the fuser is not working correctly then the paper will be room temp and their will be no print.
Apr 04, 2009 | Brother MFC 8220 All-In-One Laser Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Brother Intellifax 2800 Faint Print
did you remember to remove the pull tab to allow the new toner to be utilized? it's either that or you just have a defective toner cartridge which if you replace will take care of the issue. If you have used canned air to blow out your machine it is possible that the toner dust has been blown into the laser housing and fogging up the mirrors that it uses but that's kinda a last resort check...
May 07, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother 5140 faint print
I had the same problem and I just fixed it.
It turns out that the toner cartridge I was using was not an authentic brother cartridge. It was an Office Max knockoff.
I replaced the knockoff with an original BROTHER toner cartridge and BAM! Right back in business.
What tricked us for so long was that the knockoff worked for two weeks before it conked out, so while we were looking for the problem, we kept saying to ourselves, "No, it COULDN'T be the toner cartridge. It's practically brand new."
Hope this helps.
Dec 27, 2007 | Brother Office Equipment & Supplies
Brother HL 5250DN Laser Printer Logo
220 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
