Question about Logitech QuickCam Express Web Camera
Logitech QuickCam IM Microphone
The microphone icon has a red line through it saying that it is mute and I cannot be heard when I am using camera online.
    Scholar:
  • 144 Answers
Go into your sound settings and check if your microphone settings are set correct.
Posted on Aug 08, 2008
SOURCE:
I just installed a Logitech Quickcam 9.5 and is working fine but when I tried to use the little headset/mic included, using Windows Live Messenger (MSN or Hotmail Messenger) and I can hear everything but...
First try going to your control panel,
  • click on sounds and audio devices,
  • click on audio at the top of the sounds and audio devices properties box
  • after that your default device should be listed under sound recording.
  • click on volume where it says sound recording should have a picture of a microphone, a recording control box should pop up, make sure the microphone box has a check in it,
  • click on advanced under the microphone box, put a check in the microphone boost box.
  • then exit from the control panel and right click on the icon of the little speaker at the bottom of your task bar.
  • click on open volume control.
  • your volume control box will appear, make sure the microphone mute box is not checked.
  • then set your microphone level.
Mar 28, 2009 | Logitech QuickCam Express Web Camera
Microphone is not working
go to your volume control usually there is a icon of a speaker at the bottom left of your screen right click it and open volume control and make sure that your mic is not muted.
Feb 22, 2009 | Logitech QuickCam Express Web Camera
Microphone still muted
if you notice the speaker icon in your systray... that space with all the icon's on the lower right of your screen you will see a speaker... open that and look for a mic setting... you may have to go into the menu at the top of the window to add the control for the mic... make sure it is not muted.
Robert
Feb 02, 2009 | Logitech Quickcam Chat Webcam
Camera works but skype tells me the microphone is muted.
Go to Tools | Options | Audio Settings which is how the audio and microphone settings are adjusted in Skype.
Your microphone might be muted in the Windows multimedia sound control panel - if you double-click on the speaker in the Windows taskbar you will get the mixer control panel - select Recording devices if the Microphone is not shown, make sure the MUTE checkbox is clear.
Dec 26, 2008 | Logitech Quickcam Chat Webcam
Logitech Microphone Not working
Try using a headset. They usually work much better.
May 31, 2008 | Logitech QuickCam Express Web Camera
Logitech quick cam communicate stx on Vista - microphone not working
Why isn't the microphone on my camera working?
trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Mar 25, 2008 | Logitech QuickCam Communicate STX Personal...
Syncronizing windows
1- Well the thing is with Digital Camera If there is lots going on (on the computer) your other program might interfer
1st end all processes that might have anything to do with the camera or that may be using any of its features, I would retart your computer as well
If you still have any issue uninstall and reinstall the drivers for the camera.
2- Of course you can You have to locate the volume control located in the System Tray( Next to the clock in the lower right hand side corner) if you double click on the icon you shold have the option to mute the microphone
Good Luck
- John -
Dec 21, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech Quickcam Microphone not working
on the right hand side of your task bar near the time, you will see a speaker icon, right click on it and open volume control. When the window pops up on the far right should be the mic controls, check that it's not muted. If the mic controls do not show then click options at top menu then advanced and the mic slider controls will now show up.
Mar 19, 2007 | Logitech QuickCam Express Web Camera
Logitech QuickCam Express Web Camera Logo
136 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
