WONT TURN ON
PC WILL NOT TURN ON AT ALL NO LIGHTS NO SOUNDS HAS A ID CODE 115 ON THE BACK
  • OneSneakyBoy May 21, 2009
    i have the same problem... When i try to turn it on it wont do anything at all. And its plug into to an outlet that works. It also has that same Id code on the back ( 115 ) . I dont know whats wrong with it..
    Genius:
  • 1,447 Answers
Hi-
Try using a different power cable, and try plugging it on another power source, if all fails you might be having an issue with the power supply, if you are using an autovoltage regulator, try checking the fuse as well
keep me posted.
Posted on Aug 16, 2008
CHECK POWER SU.IF IS FUNCTIONAL BP SHORTIN PINS GREEN AN BRACK .IF ITS OK,THE FAN WILL ROTATE SHOWN THAT THE P.SUPPLY IS OK
Posted on Aug 10, 2008
When l turn my air conditioner on the lights flicker,but it wont turn on.What should l do ?
  1. LG Electronics LP1014WNR 115-voPortabAir ... - Fixya
    www.fixya.com/.../p20872057-lg_electronics_lp1014wnr_115_voporta...Recent LG Electronics LP1014WNR 115-voPortabAir Conditioner with Remote Control questions, problems & answers. Free expert DIY tips, support, ...
Jul 14, 2015 | LG Electronics LP1014WNR 115-voPortabAir...
Need activation code for corel x6
You can try this activation code:BC23-800D-394A-0ACF-89DA
Mar 06, 2014 | Corel Computers & Internet
My screen on my altec lansing hp wont turn on but lights and sounds on
Can you see anything on the screen like the logo of HP or something like that?
Apr 03, 2013 | Computers & Internet
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
When i turn my phone it wont a 4 to 8 digit code it show a phone with a lock on it
if you have not applied any code then it requires the default code....just enter the default code of your phone that might be given in the user guide of your phone or enter 12345....if the phone gets started then id the phone settings...go to security settings and turn security code off...it wont ask for code again
Mar 11, 2011 | Computers & Internet
My compute dose not start when i turn it on. It doesn't beep no video signal just blank. What could be the problem?
Do you get any lights on the PC when turned on?
Hopefully you have resolved this by now but if not....
Not a lot of info to go on here but here are some things to check...some may be obvious I know but worth mentioning...
Check the following:
1- Is there power coming from where you plug it in (can you plug something else in the outlet that works?)
2- Is the power cord plugged securely in the back of the PC? (Unplug and replug connector to be sure)
3- Is the red switch near the power plug on the back of the PC set to 115 or 230? (Try changing this and then setting back to 115)
4- Is the power supply plugged into the motherboard inside the PC?
Jun 14, 2010 | Dell Dimension 3100 PC Desktop
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
GMT 115-5B wont ignite
couple things without more info is little hard,,,first not familliar with this paticular model but I believe it has a glo igniter,,which will be located next to the burners,,should be one or two scres holding it in,if this is not glowing than u need to pulll it out and look for a crack in it if its cracked u need to replace. If this is electronic ignition will have a metal spark ignition,,the glow ignitor will be ceramic by the way,,also if u pull out the glow ignitor do not touch the element with your hands while inspecting or replacing for the oil on your hands will cause it to fail sooner. sorry back to the metal spark ignition if it is not sparking than chances are u have a problem with the combustion fan motor shutting down the gas valve before it lights. I just posted on a goodman about the fan motor and the two types and how to fix. good luck.
Oct 23, 2008 | Goodman GMS90703BXA Heater
Plzzzzz help
i do think you might need a new screen.
it sounds like 1 of the cables came loose in the back.
are there any sounds @ all?
lights?
Aug 16, 2008 | T-Mobile Sidekick ID Cellular Phone
Laptop Dead, Wont power up
Hi
This sounds like a tricky one. If you plug everything in and turn it on at the mains do any lights on the laptop come on? Does it do anything at all when you turn it on?
If you get back to me I can proceed to help you further.
Phil
Jul 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
