Question about Panasonic Home Theater System System
Error Message F61
Hi there
When i've return from holiday, i've plugged in my home cinema system
Panasonic SC-HT540 and i've noticed some sparkles coming out from the socket.
Afterwards the systems was switching on displaying error message F61 and immediately switching off.
Just for a second i can hear sound from the speakers and thats all.
All the connections are fine.
I've seen that you can provide parts and prises.
Would you please help me with any advice?
Thanks in advance.
Kind regards
Sam
  • neilthomas Aug 15, 2008
    When i switch my system on i get sound for about 3 sec and then error message F61, i have checked all the wires and they are fine but i keep getting the same message ??
  • Jakey 92 Dec 11, 2008
    I turn the dvd player on, its comes on for about 2 seconds and the sound works, but them F61 comes up on the display and it switches off.
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Posted on Sep 12, 2008
Home cinema panasonic sc-bt100 error code f61 what does it mean
I have same F61 issue, purchased a new fan fitted it today, and I have the same error code??
Dec 13, 2009 | Panasonic Audio Players & Recorders
Repeated F61 fault code on Panasonic Home cinema system Model: SC-HT990 Is it the fan in the sub woofer?
Hello
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Andrea
Dec 12, 2009 | Panasonic Home Theater System System
Panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Aug 26, 2009 | Televison & Video
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
F61 code on SA HT540 system
i think it means that the cooling fan is faulty.
cheers Mark
Jan 06, 2008 | Lands Phones
Panasonic Home Theater System System Logo
1,238 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
