Question about Sony Playstation 3 (PS3) Console
Ps3 red light of DEATH......when i go to turn on playstation3 on i get a green light then beeps flashes yellow thenback to red flashing on and off whats wrong??????
  • 3 more comments
  • esahcjv94 Aug 08, 2008
    same issue! idk what happened. the system just froze and turned off on me during the middle of a game, and whenever i try to turn it on i get the same thing you get. i looked through the manual, and it said that turning the system off by using the switch in the back before turning it on standby could cause it to malfunction, and the red flashing light could mean that it's overheating. i'm pretty sure that's not it though.
  • chipguy2 Aug 08, 2008
    yeah it's not overheating becuz i just turned mine on and it just froze then i hear BEEP BEEP i was like what the **** just happened and it was beeping red and i tried turning it off in the back right after that happened the game is still in there and everything not to mention the ****** wouldn't play blu-ray or ps3 games already i have a 60 gig does anyone know if that was the problem?
  • Anonymous Aug 10, 2008
    Same problem here if anyone has a solution please post it
  • Anonymous Aug 12, 2008
    Yes same problem 60gig ps3 everytime I turn it on it just freezes up and I have to turn it off by the switch at the back. When it first happened it flashed red turn yellow and turned off, now it just freezes.
    Any help.......
  • r8drsordie Aug 15, 2008
    I tried to play a movie and when I turned my play station 3 on the power light come on then turned red after beeping three times. I tried turning it off for 15 seconds. the turning it back on and holding down the start button down until the green light stood on but that did not work! It happened once before and all I did was turn it off in back and let it set for a day. The next time I turned it on, it worked with out a problem. Now I can't get it to stay on! It keeps on flashing red and will not work!! Some one help!!!! I don't want to send it in to Sony so they can charge an arm or leg to fix it! If any one knows of a repair place near Los Angeles, Montebello, Monterey Park, Alhambra, Ca., PLEASE let me know!! Thanx, R8DRSORDIE
  • 344 Answers
This is a system failure. It is caused (from my experience) by a break in one or more of the circuits in the motherboard. The break(s) need to be located and the solder and/or bad chip needs to be replaced. It is a tedious process, but if you have a multimeter, a soldering iron, flux, solder, ALOT of patience, and an electronics background, you could do it yourself in a few hours!! Or you could call Sony and try to get it fixed for free, or you could sell it for parts and get a new one. I hope this helps. Good luck.
Posted on Aug 15, 2008
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one spot.playstation will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
My playstation3 turned off while playing a game i then pressed the on button then a green light and amber light then a flashing red one comes up but it wont start
sounds like the yellow light of death YLOD it will need attention, you can take to get repaired for around £40/70 or if still under 1yr call playstaion and they will replace with a re-conditioned on, nearly brand new. sorry pal.
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
Red flashing light on my playstation3.
Sounds like you have the Yellow Light of Death. It is a processor problem, and needs to be completely disassembled. Try CPR in New York City. They are faster than the manufacturer, and cheaper! They have a usual turnaround of 3-5 business days. And if you become a fan on their facebook page, mention it and you will get a 10% discount.
Here is the link to their facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
My playstation wont turn on.
Repair needed. Its called "The Yellow light of death" on the internet or YLOD for short.
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
My playstation3 just cut off in middle of game, red
Thats the red light of death.
Visit this website if you want information on how to fix it.
Feb 26, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my playstation3 it wont turn on. It was workin
Your motherboard is damaged I would send it to be repaired.
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
Soon as turn PS3 on it goes orange then flashes red.
Its called the Yellow Light of Death. It can be repaired but what you need is an Infra Red BGA reflow of the solder on the PS3 graphics chip.
The best place in the UK to do it is:
http://www.playbackups.com/Playstation3-xbox-360-repair-repairs-manchester-bga-solder.html
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
139 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
