Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
IBM Laptop System Password
Hello, I have 2 IBM Laptops, a T40 and a T42. I have a system password when it is first fired up, prior to booting windows. I have forgotton one of the system access passwords. Is there anyway I can get back into the laptop? If I can do this, I still have all the passwords for my Windows system. Any help would be greatly appreciated. Thanks.
  • Le trip Aug 08, 2008
    Thanks for a very prompt response! I'll venture in and try the short circuit first then IBM. I'll post on the site how it goes. Cheers!
  • 38 Answers
If you are comfortable with taking apart your laptop, open it up, find the lithium battery (it looks like a small silver disk usually) and pull it out. Then you take a metal object that conducts electricity and touch the bottom of the battery holder to the top end of it in order to short circuit the bios memory. That way, the bios memory is reset and you can get back into your computer. If you arent comfortable with it, find a computer-sav vy friend or go to your local computer IT place and have them do it for you. OR, you may call IBM and ask them to unlock it for you, over the phone, using a backdoor that only they have access to. But again, taking out the battery and shortcircuiting the CMOS (bios) memory is easiest (and cheapest) way to get back into your computer, unless IBM is willing to help. So try calling them first.
Also, if none of this works, you may look at this link, its a bit technical though:
http://labmice.techtarget.com/articles/BIOS_hack.htm
Hope this helps...
Posted on Aug 08, 2008
SOURCE:
I have a windows xp ibm thinkpad that says
havent opend one of those yet... Does it give you a code, something like a HEXADECIMAL code of some sort, if it does there are DOS programs that can be used to find the password or reset it.
other wise there is the option of opining the NB and removing the CMOS battery wicth should reset system. This I would not advise to you if you dont have a lot of expierince with Tech work.
How ever if you do decide to do this, please read up on Google about reset CMOS on that specific model, some models will lock untill it recieves a code that only IBN should have...
Hope it helps
Feb 16, 2012 | IBM ThinkPad R40 Notebook
When booting up the computer it requires a log in and password that I don't have. How can I fix this?
Download the UBCD ( Ultimate Boot CD) it will allow you to boot the laptop and reset the password.
Feb 16, 2012 | IBM ThinkPad T40 2373 Notebook
I want to unlock my pc IBM T40
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram. Click on one of these links todownload HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jun 30, 2011 | IBM ThinkPad T40 2373 Notebook
Need ibm thinkpad t40 2373 bios password and bios circuit name
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
Dec 02, 2010 | IBM ThinkPad T40 2373 Notebook
Ibm thinkpad t42 bios password problem
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Nov 29, 2010 | IBM ThinkPad T42 Notebook
Ibm t42 thinkpad t of svp password
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Unfortunalty, no other ways other round. Thanks and have a nice day J-
Apr 16, 2010 | IBM ThinkPad T42 Laptop
BIOS locked out on IBM T40 and T42
visit this page to answer your problem. God Speed
Apr 07, 2010 | IBM ThinkPad T40 2373 Notebook
IBM thinkpad t42 boot up problem.
The sympton is rather vague, but I suggest the following options, to be followed one by one, until one of them works for you.
1) Boot your system in Safe Mode (if Windows is your OS) by pressing F8 after the usual "beep" provided by the BIOS after it detects all is fine. If it boots up, which takes a little longer than usual, then your system is probably Ok, although it may have a configuration problem.
Reboot the machine from the shut down menu and hopefully it will work Ok. If not, then, depending on whether you have Windows Vista (or better), try:
2) Boot again pressing the F8 key, but this time locate the option that reads something like "Last known good configuration". Highlight it with the arrow keys and press Enter.
If you have System Restore set on your drive(s) your laptop should boot up normally.
3) The last option would be for you to go into your system BIOS and run at least a HD detection test, followed by a memory test, etc., but I would only recommend doing this if you know what you're doing. If not, ask a friend for help.
Aug 17, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
New Password
On most computers you can access the bios menu by tapping one of the Functions keys, usually its an even number most often f8, sometimes f4 or 2 and seldom f7. Hope it helps, please rate if helpful.
May 30, 2009 | IBM ThinkPad T42 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
