Question about Cell Phones
Samsung toco How do I remove the battery cover. The manual just says slide out but there must be a little release button somewhere as I cannot just slide it out
Yeaah you do just slide it off but i find that mine gets a bit stuck but i keep on trying to get it off, it comes out in the end!
Posted on Mar 18, 2009
How to remove a battery on a samsung flip cell phone SCH-u36 ?
Just follow the discussion in the owners manual here: http://www.samsung.com/us/support/owners/product/SCH-U365HAAVZW
The battery cover on the back of the phone protects the battery.
Removing the battery cover
1. Hold the phone firmly and locate the Cover Release Latch.
2. Firmly "pop" the cover off the phone.
Installing the battery cover
Align the cover and press it into place, making sure it snaps securely.
Jul 25, 2014 | Samsung Verizon Gusto 2 SCH-U365 Prepaid...
Samsung DVR-R130 wont release the disc.
Most players will have a small hole on the front panel where you can access the manual release using a paperclip. I checked your Owner's Manual, and didn't see any mention of it, but most every DVD player I've ever seen has one. Hope this helps.
Dec 24, 2007 | Samsung DVD-R130 DVD Recorder
Tip
How to remove the battery from a Samsung Intensity cell phone
If you ever need to replace your Samsung Intensity's battery, or if you just want to remove and reinstall it to reset the phone, getting the battery out is a piece of cake.
First, turn your phone off by holding down the End button (the button to the far right of the directional pad) for a couple of seconds, until the phone begins to shut down. Then turn the phone over so you're looking at the back of it. (The battery can be removed with the slide-out keyboard either out or in, but the phone is a little easier to grip if the keyboard is in.)
The rear cover of the phone pops off easily as one piece. You can fit a fingernail in the groove along the top of the cover (by the camera lens) and the cover should come right off. Once the cover is off, you're looking right at the battery. It's the rectangle-shaped thing in the middle of the phone (that probably says "Samsung" on it). There is a little ditch on the bottom edge of the battery where you can put your finger to lift the battery out of its cavity, and once you lift it up it can be removed easily.
When reinstalling or replacing the battery, slide the top side (the side with the three gold contacts) in first, and the notches will line up as the battery falls into place. The battery is keyed so it can only be inserted one way; if it does not slide in easily, make sure the gold contacts on the battery are lined up with the gold contacts on the phone. When the battery is back in, reattach the rear cover (making sure it snaps into place) and turn the phone on by holding down the End button for a second or two.
on Jan 17, 2011 | Samsung SCH-U450 Cell Phone
How To remove the cover from Samsung SGH M-200
To remove the cover of the phone, you follow the process below:
Remove your back cover by pressing down the black part and sliding it downward, remove your battery and sim. Two screws need to be removed,
There are four slots in battery compartment. Two are by the left side and there are two opposite. Push a mobile phone opening tool into each slot and then turn it. This will release the clips that hold the battery compartment in place, now you have the back cover removed
Next release the clips that hold the front cover,
Just gently unclip the hooks that clips the front cover, there are about 6 hooks by the sides, 3 on each side, now you have both back and front cover removed.
Take care and good luck
Oct 14, 2010 | Cell Phones
How to unfreeze samsung a736
Well first of all you can just remove the battery from your phone, the battery is located on the back side of your phone, Remove the back cover of the cell phone. Some Samsung phones have a plastic outer cover over the battery, while on other models the back of the phone is the back of the battery itself. Locate the release button or slider on the back of the phone. Depending on the Samsung phone model, the back cover or battery itself will slide downward or lift off when the release button is pressed or the slider is pushed upward.
Just insert the battery after 30 seconds, and then turn on your phone. hope this helps. Please post comment if further you have the same problem.
Good Luck!!
Thanks
Jan 12, 2010 | Cell Phones
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Jan 03, 2010 | Panasonic Toughbook CF-51 Notebook
Getting battery cover off a nokia 6500
Using your thumbs, trying sliding the back cover toward the top of your handset.The back cover should release from hinges and you can use your fingers, nails or small tool to lift the battery cover off. With this device specifically, the thumb feature is needed.
Hope this helps!
Mar 19, 2009 | Nokia 6500 Slide Cellular Phone
Battery replacement
There is a button for the battery cover release on the bottom of the mouse. Slide the wireless usb adapter out and the button should be there.
Nov 05, 2008 | Logitech 3-Button Cordless Optical Scroll...
Unlocking Disc Tray?
If you want to remove the entire tray, remove the top of the casing and the the front as well. The front is held on by a screw on top and two smaller screws, one on each side. Then remove this face plate by releasing the clips built into the unit, two on each side, two on top, and two bigger ones on the bottom. Try to just lay the face plate/front cover down beside the unit to avoid the effort of disconnecting the other pieces. Remove the two screws, one on each side, of the dvd laser top cover. Remove the two screws under that, one on each side, they're also accessible without removing the dvd laser top cover at all, but either way all four screws need to be removed. Remove the center screw holding the top of the tray/turntable. Then remove the turntable top, you'll have to pry this up near the dvd laser while sliding it around to get it past the two interlocks(inch wide lip overhanging) built into the tray bottom. This may not be necessary to remove, but it makes it easier to slide the tray out later. Next remove the two screws holding the tray mounting brackets in place, there is one located on each side near the front. You may only have good access to one side and should remove it first to give yourself more room to work on the tighter side. You may even be able to pull the tray out without removing that side's screw and bracket at all. The tray should slide out of the front then, like it does when it opens during normal operation. At least put the top cover to the dvd laser back on, and if you're wanting to reattach the top of the turntable, remember to do that first...before attaching the dvd laser cover. There may be one or more screws somewhere I didn't mention to remove, it's been awhile since I took one apart. And of course, don't look at the dvd laser and don't mess with the two 250v capacitors...they will still be charged and can shock you. They'll look like two black cylinders, side by side, each about the size of a C battery or a little smaller. Most likely you should be fine unless you remove the power supply board and make contact with the soldering points on the underside. Just try not to slip the screw driver and so forth. Hope this helps, it's about all I could remember, so look for other attachments, screws, etc if you get stuck.
Jul 07, 2008 | Samsung HT-Q70T System
Acer extensa 4620z battery location
1 Slide the battery release latch to release the battery.
2 Pull the battery from the battery bay.
Apr 21, 2008 | Computers & Internet
Cell Phones Logo
283 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
