Question about Gigabyte GA-8I845GVM-RZ Motherboard
No display - 8I845GVM-RZ
Sir,
im not getting display nor the keyboard is detected. when i power on processor fan starts rotating no other responce... Pls help me with ur support
  • 1 more comment
  • sbonelo mlita Aug 13, 2008
    I also have display problem, I changed to vista, then the drivers I had did not work, then I'm trying to get drivers to work for windows vista. I cant get them
  • anilsah Nov 11, 2008
    sir,
  • Anonymous Dec 02, 2008
    Same problem. When I started for half hour, the power suddenly shut down. I found 2 K3686 broken. I replaced with 50N03H and fan began to spin but no any live sign. the diagnose card read 80 and stayed there.
I think the problem is with bios...have u updated the bios recently...
Posted on Jan 10, 2010
  • vistkirru Feb 11, 2010
    thank u for helping....but i repaired my motherboard from gigabyte showrooom....they said oe of the chip has burned and replaced it by charging 650 rs....
    Problem Solver:
  • 6 Answers
Shout down your sysem ,and remove ram in ram slot clen dust replase it ,and remove proseser fan and open the prosessor in posesor slot clen the dust one more time completly clen the dust in cpu, now insert the ram in ram slot and insert prosessor in prosesor slot and lock it insert the prosesorfan also ,now power on your system
Posted on Aug 08, 2008
Im not finding the link for gigabyte 81845gvm-rz motherboard driver please help............
Here's the link...
http://ee.gigabyte.com/products/page/mb/8i845gvm-rz/download/driver
hope that works
Jul 21, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Can 8I845GVM-RZ-C motherboard support Intel Core 2 Duo(dual core) processor?
support the Intel's Core™ 2 Duo mobile series, as well as Core™ Duo LV / ULV, Core™ Solo ULV and Celeron M processors
Good luck ! if your problem solved don't forget to vote
Dec 30, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Actually my system is having the problem like motherboard LED is not glowing, powersupply fan processor fan not spinning sometimes it works properly by putting supply ON. All power supplies are normal from...
I would still say it is power supply! Check with power supply from another computer.
You have intermittent power supply to the fan, you have no power supply to the motherboard, processor fan is not spinning , not is indicator diod on the board, first instance and easiest to check is always power supply.
If power supply is not a reason, check on motherboard high volume capacitors, especially around processor, capacitors should have flat tops, if tops are buckled, that meant capacitor/s is/are gone and motherboard can be used as a decoration, if you do not have special soldering iron to replace surface mount circuitry, do not bother even to think to replace them.
Aug 15, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Problems with Gigabyte GA-8I845GVM-RZ Motherboard
nothing but the fans run.the hard drive will run if i unplug the ribon.I changed the power supply and still not working
Mar 08, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
System not rebooting after BIOS update
may be u have flasshed a wrong bios to ur mother board u have to take it to service centre it basically bios dead can be repaired at cost , try removing RAM and then re install them see if it works
Feb 21, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
I want to download gigabyte 81845GVM RZ Audio Driver can anyone help me in this regrad...
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1767
8I845GVM-RZ Enlarge View
8I845GVM-RZ
AddThis Help
1. Supports 533MHz FSB Pentium® 4 Processor with HT Technology
2. Support high performance DDR333/266 memory
3. Provides 6 USB 2.0 ports for high-speed connectivity
4. Integrated new generation Intel® Extreme Graphics Engine
5. Integrated Ethernet 10/100Mb Network Connection
6. Integrated high quality 6-channel AC' 97 audio
Audio
Download Date Description Version Size
Download from ... 2006/12/19 Realtek AC97 Driver
O.S. : Windows 98,Windows Me,Windows 2000,Windows XP,Windows XP 64Bit 5.10.00.6160 30.47 MB
Jan 06, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
USB drive is not working - Drivers are installed.
Hi I m using Gigabyte GA-8I845GVM-RZ Motherboard USB drive is not working, printer, data cable, pen drive everying is not working but all the drivers are installed properly. Advise please. Arul selvan. M
Sep 03, 2008 | Gigabyte GA-8I845GVM-RZ Motherboard
Gigabyte GA-8I845GVM-RZ Motherboard Logo
235 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
