Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
XBOX 360 MY CONSOLE DOES NOT PASS THE TEST FOR MY IP ADDRESS.HOW CAN I FIX THAT? I'M USEING THE ETHERNET CABLE FROM COMPUTER TO THE XBOX 360. SO THAT CAN PLAY ONLINE WITH 360, BUT THE IP ADDRESS IS SHOWING FAILED ON IT. CAN ANYONE OF YARD GUYS OR WOMANS, OUT THERE CAN HELP ME FIX THIS PROBLEM?
  • 1 more comment
  • Anonymous Dec 27, 2008
    i have the same problem in i need it bad and now help me
  • Anonymous Jan 10, 2009
    it passes the first two test but fail when it get to the ip test
  • elirandom Feb 15, 2009
    Yeah I have the same problem, i go out and spend $150 au on a network adapter and it doesn't work, I've tryed calling up but it didn't help any other help would be greatly appreciated.
    Problem Solver:
  • 9 Answers
Put in a manuel ip address the same as youre routers on the setup on youre xbox,good day
Posted on May 18, 2009
  • samk19 May 18, 2009
    you could try connecting the xbox dirrectly to youre router rather than two youre computer
  • 76 Answers
Go to a computer on your network
type cmd in the run box press enter the type ipconfig/all and press enter write down the ip addy the default gateway and the dns numbers
go into your xp and set everything up yourself
Posted on Mar 12, 2009
When testing the connection for xbox live it can't find the IP address.
Xbox 360 Connection Tests: IP Address
This test verifies that your Xbox 360™ console has a valid IP (Internet Protocol) address.
If your console does not pass this test:
Confirm that there are no other devices on your network with the same IP address.
If you are using a router or gateway, verify that it is configured to assign IP addresses to network devices (DHCP-enabled).
If you are connected to a router, make sure that your console'sEthernet cable is not connected to the router's LAN port rather thanits WAN port.
If you are connected directly to a modem and your ISP (Internetservice provider) requires PPPoE settings, verify that your PPPoE username and password are correct. If your ISP doesn't require PPPoEsettings, remove the PPPoE user name and password settings.
If you are connecting directly to a modem and have replaced a devicethat was connected to your modem with your Xbox 360 console or anotherdevice, turn the modem off and back on before connecting the newdevice.
If you are using a static IP address from your ISP, verify the address with a your provider.
If your console is connected to an ad-hoc network (in which devicesare connected directly to each other), it will probably not pass thistest. If your IP address is assigned automatically and your ad-hocnetwork does not include a DHCP server, this does not indicate aproblem. The test is properly reporting that a DHCP server could not becontacted. Xbox Customer Support does not support the use of ad-hocnetworking to connect to Xbox Live.
If you're using an ad-hocnetwork without a DHCP server and you can't connect to Xbox Live, checka different diagnostic test for the root of your problem.
This comes from http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testipaddress.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 31, 2009 | Microsoft Video Game Consoles & Games
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox live ip address test fails
If you are using Windows XP or below, press START, click RUN and type "cmd". If you are using Windows Vista, press START, click the search bar and type "cmd". The command prompt should appear.
Type: ipconfig /all
Search the list for your network adaptor and make a note of the MAC address.
Turn on your Xbox 360 and go to network settings. Select manual settings and enter the MAC address under the Alternative MAC address option. Retest the connection. If your computer is connected to the internet, your Xbox 360 will be too,
Jan 24, 2009 | Microsoft Xbox 360 Console
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
Ip addresses
the wireless adapter is when you have a wireless router,take off the adapter and plug the ethernet cord from the modem to your xbox
Jul 13, 2008 | Microsoft Xbox 360 Console
Ip addess
if you are using an ethernet cable make sure its connected directly into your Modem and not a port in your PC
May 10, 2008 | Microsoft Xbox 360 Console
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Xbox 360
did you unplug the same cable from the computer to your Xbox?
Dec 06, 2007 | Microsoft Xbox 360 Console
UNABLE TO FIND IP ADDRESS
I think the Ethernet cable needs to run directly to your router/modem, you can't bypass it through a laptop (as far as I know!)
Nov 18, 2007 | Microsoft Xbox 360 Console
X box 360
You can't get an IP address on the Xbox that way. You need to get an IP address from a device that works as a DHCP server such as a residential router. Connecting the Xbox to the PC will do nothing for you.
Nov 08, 2007 | D-Link DI 514 Wireless Router (DI-514)
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
208 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
