Question about Panasonic Microwave Ovens
I have a PANASONIC NNE273S microwave. The light, motor and touch panel works but there is no heat!!
  • winstan01 Aug 11, 2008
    yes the light & turntable come on, the noise is no different than usual.
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
  • Panasonic Master
  • 9,086 Answers
Under those circumstances, I would suspect your magnetron has failed, or there may be a bad connection at the magnetron.
Posted on Aug 11, 2008
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
Change the fan tone of the nnct585s microwave oven by Panasonic so that it makes the same fan tone as the nne273s because I used to the fan tone of the nne273s
Microwavemanual.com probably has a manual for this oven.
In general, though, tones on most microwaves seem to be set, except for loudness on some.
May 29, 2016 | Panasonic Microwave Ovens
Why is the outside panel hot to the touch?
Many factors at play here. Are you cooking on the range? Are you using the microwave? Is the light on?
There is very little current going to the touchpad and if there were a short in it the touch pad would not work. It is just heat from another source. Don't worry about it.
Dec 13, 2014 | Maytag Appliances Over-the-Range Microwave...
Push button not working on front panel
Possible that the panel is faulty specially if this is a touch pad. If so you need to replace the pad.
You can use a dryer to heat off moisture which can help in some cases.
Jan 30, 2013 | Panasonic Microwave Ovens
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Panasonic Microwave NN-S935BF turntable and light do not work. Microwave still works. Bulb and turntable motor okay. No power to light or turntable. Any ideas?
Your description seems to be confusing turntable and light do not work
Bulb and motor OK
Which is it?
They could be separate incidents. The drive motor could be fused and the globe just blew its life away..
Aug 15, 2009 | Microwave Ovens
Intermittent heat in microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Light, turntable and fan don't work
Possibly the light bulb has blown, which has blown on a track on the board which has taken out the turntable motor and the fan. Also, there could be a problem with the door switch.
Mar 27, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
