Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Error 1068 on vista print spooler stopped
warren124 on Aug 08, 2008
While trying to install a windows xp version of a lexmark x4270 on to a vista and download the drivers for vista my printer spooler stopped and will not restart. I've done a reboot, deleted printer drivers and reinstalled them. Went to services and pressed start spooler, nothing. Help!
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Apr 06, 2009
-   I have same problem as Warren124. I think it is safe to say that the printer WAS NOT compatible for me in this instance. I have downloaded regfix and this has not helped. I cannot start the spooler and get a 1068 error when I do. I am running vista. Any guidance would be great as I am totally stuck to do my homebased work. Cheers -   Guest
Sep 05, 2008
-   I have a X2250 Lexmark, also when trying to install it stops saying the spooler service has stopped and everything goes bad from there. It is Vista 32 with latest updates. Tried the whole clean drivers and registry things from all the other forums, but still can't print to the printer. -   renes774
Best Solution
posted on Apr 12, 2009
Helpful)
Roop1980
Rank: Wiz  Lexmark ExpertLexmark Expert
Rating: 84%, 111 votes
Please follow the below given steps to remove the dependencies.
1.Click start icon.
2.Click on All Programs.
3.Click on Accessories.
4.Click Run.
5.Type cmd and hit enter.
To remove this dependency all you have to do is open the command prompt and type in the following command:
Please type Sc*config*spooler*depend=*rpcss (put spaces where the (*)’s are.
When you hit enter you will get this message:
Sc config spooler depend= rpcss [SC] ChangeServiceConfig SUCCESS
Now please restart the computer and try to install the printer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Aug 19, 2008
Somewhat Helpful)
leanbicycler
Rank: Wiz
Rating: 78%, 258 votes
well..for beginners, did you check for the Vista compatibility with this printer? Also, you MAY need SP1 for Vista, which had a ton of driver updates.
http://tinyurl.com/6qcpgy
Was this helpful?
Yes
No
Related Problems
my printer stopped printing.
moved from XP to Vista. Printer not printing correctly. Have...
Hi! My name is Cassandra. I need help on how to send a fax,...
I need to install my Lexmark X4270 printer, but I also have...
Can you Help with these Printer problems?
can recieve faxs but cant send them...
Solve
can recieve faxs but cant send them keeps saying failed to connect
DSP-A3090 YAMMAHA 7ch no main...
Solve
DSP-A3090 YAMMAHA 7ch no main channel working
fax number disappears when I press...
Solve
I input the fax number and when I press the start button the fax number disappears from the screen... (More)
Printing with lines primarily in the...
Solve
Put in new black ink cartridge and it still will not print clearly
Keep getting line error on my...
Solve
I have a line with a separate fax number than my house number. I have a splitter that splits my... (More)
Sponsored Links
Describe your Printers problem:
Top Printer Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Printer Experts
Top Printer Repair
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Repair & Parts
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
