Question about Cell Phones
Phone charger NEED A CHARGER IN JOHANNESBURG (S.A)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Hi there, what phone do you need a charger for?
Posted on Aug 14, 2008
  • Bertus Olivier
    Bertus Olivier Aug 15, 2008
    Hi there, I don't know where in JHB you are but you can try the flea market in the east rand, there is a shop there that does stock it. their tel number is 0824115997 his name is johnny.
Charger problem how to identify
Hi, to identify charger. You will need to test another charger on the cell phone and test that same charger on another phone to confirm if the charger is working.
Also after testing for the charger and and if the charger works, that means the charging port of the phone where the charger is been inserted is damaged.
It will need to be fixed.contact you local repair person for help.
Take care.
May 22, 2011 | Cell Phones
Every 5 minutes or so it beeps and says it is not charging although the phone is not even plugged into the charger. When you switch it on at first it says it is charging with the bar graph indicating this...
Hi, would have told you too replace two things on the phone,
The charger and the battery.....
But sometimes the charger port where the charger is being inserted into the phone might be faulty too,
So you will need to test for the charger port. Get a new charger and a new battery, and insert the battery and plug in the charger...if nothing happens, that means you will need repair the charging port....
Consult a phone repairer for help...
Hope that helped...
Feb 03, 2011 | Nokia 6110 Cellular Phone
Cell won't charge even with a new battery
Try to use or buy universal charger. Get your battery and charge it to universal charger. so that you can use your phone. This is the easy way so you can use your phone.
Jan 25, 2011 | Cell Phones
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
My casio boulder will not charge how do I fix it
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
Jun 15, 2010 | Casio G'zOne Boulder Cell Phone
Hi I have N95 and when i plug charger in it says not charging can anyone help
Please check the charger by plugin with some other nokia handset and check if the charger is working fine. If still it shpws not charging with other handset then change the charger as charger is not working
Jun 01, 2010 | Nokia N95 Cellular Phone
Why doesn't my htc phone charge while plug in?
First, you need to check to see if the problem is with the phone - the battery - or the charger.
If you have a car charger, try to charge the phone with it. If it works, you'll need to replace your home charger.
If the car charger doesn't charge the phone - you'll either need to replace the phones battery or your home charger. (Sometimes the battery will go bad if you use a car charger not made specifically for the phone.)
If you replace your battery and it still doesn't charge you'll need to replace your home charger.
If after you've replaced the battery and the home charger and it still doesn't charge - your problem is with the phone and it will either need to be replaced or repaired.
Apr 07, 2010 | HTC FUZE Smartphone
The charger that pluges in the wall failed and melted the wires and the outlet in the wall. sould i buy another phone or charger.
You definitely need to purchase another wall charger.
However, before you purchase another phone, use a car charger to determine if there is a problem with your phone. If the car charger does the trick then you should be able to purchase just another wall charger.
And, make sure when you purchase your new wall charger that it is an OEM (original equipment manufacturer) charger and not a cheap knock-off.
Feb 02, 2010 | Inter-Tel ECX 1000 Telephone
My charger is broken.
yes if your phone do not detect any charger than you need to buy a new charger. because whenever you connect a charger, than the mobile displays "battery charging0"
Sep 08, 2009 | Verizon Communications enV2 Cellular Phone
I need a new screen pen charger and cover for cect c6000 tv cell phone Im in soth africa johannesburg.
Look on ebay you should be able to find replacements for all the items you are looking for.
Aug 12, 2008 | Cell Phones
Cell Phones Logo
66 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
