Question about Motorola Mobility H700 Wireless Headset
Blackberry to motorola pairing
OK I tried my luck and its a waste of time. My H700 has a small button marked M and a big button with telephone engravings on that. Pressing the button sometimes its purple and at times it blue. Blackberry open there searches and says no device searched.
Can some one enlist the steps for me. Can you tell me like ok press big button count to 10...in this style?
  • jundog13 Aug 09, 2008
    how do i turn my bluetooth on so i can use it?
When you turn on do not remove your finger from the switch for about 15 seconds. This will make your headset go to a solid light and that is when you can pair the unit with your phone.
Posted on Aug 08, 2008
Im unable to pair my H700 to my BlackBerry 8300
1.)Turn on your BT on the 8300,
2.)Press and hold the button on your H700, flip open the boom when the light turns blue.
3.)On Blackberry go to BT setup and select search, it should find it.
4.) when it askes for the PIN enter "0000" and OK
it should then be connected.
Jan 08, 2010 | RIM BlackBerry 8300 Smartphone
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
H700/ blackberry storm
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 11, 2009 | Motorola Mobility H700 Wireless Headset
Motorolla headset h700 pair with blackbery
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 06, 2009 | Motorola Mobility H700 Wireless Headset
Having problems pairing motorola h700 with blackberry curve
Mar 23, 2009 | Motorola Mobility H700 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Won't detect Motorola H700
Hi David, I want you to go to this link for your nokia E65. Click the link.
http://europe.nokia.com/link?cid=PLAIN_TEXT_119729
On the left side of the page click Demos
When the demo window opens click, Select Demos button.
Scroll through the list until you see Sending Via bluetooth.
Follow the interactive instruction to connect to your H700.
You'll need to set your H700 into pairing mode when searching for the bluetooth H700.
It might be a good idea to book mark the main page.
Good Luck! Take your time.
Mike
Apr 04, 2008 | Motorola Mobility H700 Wireless Headset
Need a passkey lost it
The problem you are having with your H700 is not the passkey. "0000" is correct. The problem is the pairing process. I just paired mine after reading this with my blackberry curve.
1. Close the H700.
2. Hold the big button down until you see a lavender light.
3. Open the H700 while still holding the button down.
4. At this point it is ready to be paired. If the light changes color, the H700 has timed out waiting to be paired and you will have to do steps 1 thru 3 again.
5. With the lavender light on the H700 go through the pairing procedure on the blackberry.
Mar 21, 2008 | Motorola Mobility H700 Wireless Headset
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
23 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
